Pages: 1 [2]
Author Topic: OWB for primary use with coal  (Read 22754 times)
fireboss
  • OWF Brand: central boiler
  • OWF Model: 6048
Re: OWB for primary use with coal
« Reply #15 on: October 15, 2011, 04:33:07 AM »
scott7m what if i was to weld a rack in my 6048
mcarter
  • OWF Brand: HeatMasterSS
  • OWF Model: MF5000e
« Reply #16 on: October 15, 2011, 09:19:37 AM »
fireboss, would that void your warranty?
HeatMasterSS MF5000E by Yoder Heating
MS 460 Stihl Magnum
Husqvarna 345
8lb Wood Splitter with 'High Performance' Fiberglass Handle
5 acres
« Reply #17 on: October 15, 2011, 01:17:23 PM »
 I think MCarter has a good point. Always check with the furnace manufacturer before making modifications.
fireboss
  • OWF Model: 6048
« Reply #18 on: October 15, 2011, 03:43:10 PM »
good point
mcarter
« Reply #19 on: October 15, 2011, 06:52:09 PM »
Would a heavy gauge steel grate that is 'free floating' be an option? You could slide it in when you use coal to lift it off the bottom and allow the appropriate air flow.  You wouldnt need to weld it in permanently.  I really have no idea if this would work or not, I've never burned coal.  Good luck!
Michael
MS 460 Stihl Magnum
Husqvarna 345
5 acres
fireboss
  • OWF Model: 6048
« Reply #20 on: October 16, 2011, 05:24:52 AM »
I want to try it! wood is not a problem  I just cant stop messing with my wb
« Reply #21 on: October 16, 2011, 05:48:07 AM »
Coal also needs a good draft to burn well, I don't know how well it would do with a natural draft furnace designed to burn wood. If you try it let us know how it does.
fireboss
  • OWF Model: 6048
« Reply #22 on: October 16, 2011, 06:54:19 PM »
I  have a draft inducer ''fan'' on it . The guy i  work with just got a coal stove i will ask him for some coal to try it !
Pages: 1 [2]
