Author Topic: Looking for suggestions on how to clean the firebox  (Read 13264 times)
mgw44
« on: October 16, 2011, 07:05:53 PM »
I'm looking for tips on how to clean the firebox.  What is the best tool\method you have for cleaning your firebox?  Thank you in advance,
mgw44
oldchenowth
Re: Looking for suggestions on how to clean the firebox
« Reply #1 on: October 17, 2011, 04:22:09 AM »
An 8" drywall knife and a flashlight.  Safety goggles would also be on my list for next time too.  Trust me on that one.  And maybe a chiropractor on speed dial
jdlieland
« Reply #2 on: October 17, 2011, 04:47:05 AM »
I use a floor scraper with a long handle, works pretty well if you have a owb with flat sides.
Heat source 1
Stihl 362 pro
Stihl 192 pro
Husqu Rancher
Kabota 4510
kubota Rtv
68 acre farm
45acres wooded.
hedge and hardwoods.
Southern Ind
peacmar
« Reply #3 on: October 17, 2011, 04:59:49 AM »
A super super super hot fire from a cold start up works pretty well. Just get it roaring, leave the door cracked and a close eye on it.  >:D
mgw44
« Reply #4 on: October 19, 2011, 10:56:11 AM »
Thank you for the suggestions.  The drywall knife worked well and I have a long handled scraper on my shopping list.  I am also thinking that when the cold weather arrives this will be less of a daunting task due to hotter fires and less smoldering.
mgw44
« Reply #5 on: October 19, 2011, 11:06:22 AM »
Burning aluminum cans supposedly will get rid of most of the creosote. I never tried it though.
mikenc
« Reply #6 on: October 19, 2011, 07:53:09 PM »
Tried it, didn't work for me.  I through about 15 in and had no change in mine. Well maybe i didn't put enough in fire box at one time . Fire made short order of those. I took old garden hoe and ground it to fit the inside of drum to scrape out  inside. Get a good hot fire and scrape creosote right out.
« Reply #7 on: October 19, 2011, 10:00:51 PM »
I think you probably would need a garbage bag full to do much.
mcarter
  • OWF Brand: HeatMasterSS
  • OWF Model: MF5000e
« Reply #8 on: October 20, 2011, 09:19:37 AM »
Though I have read this, I have not tried it.  "A handful of table salt, once per week, turns creosote into harmless flakes".  I would love to know if this works.
Does anyone have any thoughts on this approach?
I recently read about about how creosote formation in the firebox acts as an insulator, decreasing thermal transfer to the water tank and rendering your OWB boiler less efficient.  I haven't had my OWB for a full year yet and I'm still learning lots of important details like this.  It would be awesome if this forum could create a generic OWB manual for newbies like me!
Anyways, try the salt on your's first and then let us know! :)
Michael
« Last Edit: October 20, 2011, 09:37:37 AM by mcarter »
MS 460 Stihl Magnum
Husqvarna 345
5 acres
tatespa
« Reply #9 on: October 20, 2011, 12:31:47 PM »
What about those Chimmney Sweep logs? They're supposed to break down the creosote..?
« Reply #10 on: October 20, 2011, 07:42:58 PM »
It def worked when I was burning wood in my house..I did throw one in my owb.. Honestly I can't say if it did worked or not.. Same with the ash-tol. by CB..Best bet to get rid of creosote is a hot fire...
red devil
« Reply #11 on: October 21, 2011, 04:05:00 PM »
Ihave heard of old timers throwing rock salt in to clean their flues on indoor stoves. That being said I think I would check with someone before  throwing any kind of salt in outdoor boilers just worried about rotting out issues.
mikenc
« Reply #12 on: October 22, 2011, 08:11:00 PM »
Heard that to about rock salt. Don't beleive I will try that either, since salt and steel don't mix very well.
« Reply #13 on: October 22, 2011, 10:54:42 PM »
I've also heard by old timers they use to throw in batteries in the  wood stove..When the battery burned it put out a chemical that would react with the soot..act like a chimney sweeping log...
