Author Topic: indoor pex lines  (Read 6946 times)
newmod
  • OWF Brand: HOMEMADE
indoor pex lines
« on: October 22, 2011, 10:01:37 AM »
Is it OK to use any indoor pex line with my OWB as long as it has the " O2 Barrier "?
Newmod
jackel440
Re: indoor pex lines
« Reply #1 on: October 22, 2011, 10:44:24 AM »
None of my pex is oxygen barrier.I know all the tubing in my shop floor is all regular pex.The only issue is if there is cast iron in the system.
New Holland LS170
24' Titan deckover gooseneck
96' Dodge Ram 2500 V10 4x4
Stihl 025
Stihl 038 Magnum
Stihl 041 AV
« Reply #2 on: October 22, 2011, 10:48:54 AM »
OB pex is only needed on pressurized systems.
Any pex should be fine.
newmod
« Reply #3 on: October 22, 2011, 10:50:24 AM »
Great thanks.
juddspaintballs
« Reply #4 on: October 27, 2011, 06:12:15 PM »
Any PEX should be fine.  I would recommend a corrosion inhibitor if your OWB manufacturer allows you to use one, though.
