Author Topic: The Heatmor Warranty?  (Read 27817 times)
MyLeakyWoodDoctor
  • MyIcyLeggedWoodDoctor
« on: January 04, 2009, 02:02:19 PM »
Would Heatmor request that an entire 2000 lbs furnace be retured to them for acessment?
Would Heatmor consider an entire 2000 lbs furnace a "part" that they could request be returned for repair?
HarrisCustomHeating
Re: The Heatmor Warranty?
« Reply #1 on: January 15, 2009, 09:57:02 AM »
We are the Distributer for Heatmor for Western Canada we've been distributing for 13yrs only had 9 fail in all of western Canada.  In ever case Heatmor has replace the unit on site.  I can't say about any were else but that's what has happened here.
James
www.harriscustomheating.com
MyLeakyWoodDoctor
« Reply #2 on: January 15, 2009, 05:18:49 PM »
Well, I was that close to buying a Heatmor, I really was!
The rest is history!
Care to comment on another eye opener . . . stagnate water pockets!
You have to maintain circulation in your open system all the time to prevent pockets of stagnate water from forming.  Inside these pockets corrosive electrolytic loops can activate right on the metal plating.  These tiny corrosive reactions are virtually isolated from any boiler treatment or anodes you may have installed and if not broken by some level of circulation can eat a neat little hole straight threw the plate.
Do any dealers tell you that in the off season (summer) you still have to maintain circulation in your boiler and lines?
Am I right here or what!
HarrisCustomHeating
« Reply #3 on: January 17, 2009, 08:19:40 AM »
With Heatmor being all 10 gauge 409 stainless steel it should not be a problem.  Plus the the feed line is at the bottom of the unit and return at the top to stop any thermal layering or stagnate water pockets.  The failure we have had all happen in the first two years of running their units and Heatmor via us has replace each on site.  The Warrenty cover corrosion and you can leave the pumps running in the summer if you like, they take very little power for the most part.
James Harris
Scratch
  • OWF Model: CB6048
    • Edge Metalworks
« Reply #4 on: January 17, 2009, 11:35:26 AM »
James Harris
Are you supposed to leave the pumps running during the summer?  What if you don't?
Hudson, WI
HarrisCustomHeating
« Reply #5 on: January 17, 2009, 04:25:50 PM »
No you don't have too, I don't.  But it would stop any water from becoming stagnate, but the only Heatmor to fail do to corrosion the water was high in sodium to the point the customer does not drink their water taste too salty and they didn't put the additive in the water.  So when Heatmor gave them a new unit we asked them to use clean water and to put the additive in.
James Harris
« Reply #6 on: January 17, 2009, 04:54:29 PM »
could you go a little further on your warranty..i tried do download from your link the fullwarranty info and the link seems broken..i would like to question you on the part i can read on your page..."if warranty requires replacement of any part Heatmore will take responsability for the actual cost of the replacement part only, the customer is responsable for transportation cost and labor"    from what i read in the first paragraph, my new heatmore is covered for 5 years at 100 percent on the weldment and ashpan (this seems not to include a leak in the metal itself only the weldment)  so lets say my stove had a bad spot in the firebox or the water jacket...does this mean heatmore will supply me with a patch to cover the whole (this being what they would call the replacement part?) or would they send me (at my expense for the shipping) a whole new firebox or water jacket at my expense(as it states i must pay transportation)  and then i would have to pay heatmores technition (or  hire my own) as the warraty states i am also responsable for labor??
"if i read this properly and i was a dealer i wouldn't be bragging about "our great warranty"
please enlighten me if i am reading this thing wrong
HarrisCustomHeating
« Reply #7 on: January 18, 2009, 09:18:11 PM »
The weldment is the firebox and water jacket(every thing that touches fire or water).  The ashpan is the fire brick and ashtub it's almost all under the sand.  I can't say what Heatmor will do every time just what they have done on the few times we have need warranty.  And that is that has been more cost effictive to replace the whole unit.  When a Heatmor goes down they and we want it back up and running as fast as possible this has ment, replace the unit asap.  To build a weldment or ashpan and ship it would take to long.  There were No Charges to the customer.  Now there are parts that can be replace the inner door, fans, firebrick, bladder, aqustats or fire grates.  A Heatmor is very easy to work on, if the custom wants a service call for these part there could be charges.  For us  to go say 500km to change an aqustat yes I would charge for the trip but we run Western Canada, some dealer with a smaller area may or may not charge for that.  A customer that has never change an aqustat before should be able to change it in less the 15min.  Heatmor has what I would say is by far the best warranty of any outdoor wood furnace this is the main reason we took on the brand 13yrs ago.  The first 5yrs is a 100% covered on the weldment and ashpan and after that it is prorated.  But I must point out that in 13yrs we have only had 9 units fail in all of western Canada.  I've had one pump and one aqustat go on my unit at home in the last 7 yrs and 1 pump go on the unit at the office in 13yrs.
« Reply #8 on: January 19, 2009, 04:11:39 AM »
thank you for clearing your warranty wording up for me, it sounds much better the way you explain it
MyLeakyWoodDoctor
« Reply #9 on: January 20, 2009, 07:23:35 AM »
So! Why did I go with Wood Doctor you might ask?
Good Question!
My furnace is leaking all over the ground in the dead of winter and they say disconnect it and ship it to our plant in Manitoba at my own expense so they can assess it!
I sent them a complete warranty claim package document with diagrams and pictures exactly where and what the problem was with an attached quote frm a local Engineering company for repairs and they say they need me to ship it to them so they can look it over themselves.
I'm going to post all this information as well when I get a chance, my warranty, my claim, pictures . . . the whole shooting match!
The warranty that's no warranty at all!!!
eco-extend
« Reply #10 on: January 20, 2009, 02:10:01 PM »
give it to them :bash: no reason for the BS warranty
piper
« Reply #11 on: January 21, 2009, 12:55:26 PM »
since you have so much trouble with your wood doctor , i will mark that name of owb off my list .no sale to me.
piper   kevil ky.  the western part of the state
Jason
« Reply #12 on: January 21, 2009, 07:57:15 PM »
Piper, just wanted to pass along that I'm real happy with my Hardy H5.  It provides more than enough heat, has very satisfactory burn times, I have the grates so I can burn coal, and the whole thing is stainless.  I've had it for about 3 years now and have not one single complaint.  The manufacturing workmanship is excellent and the materials seem to be holding up well, knock on wood.  As a suggestion, give their website a lookie loo and see what you think.
www.thehardy.com
-Jason
Jason-Pittsburgh, PA
Peter764
  • OWF Brand: Heatmor
  • OWF Model: 400-4S
« Reply #13 on: November 10, 2012, 06:50:06 AM »
I purchased a heatmor model 400-4S in June of this year. The manufacture date on the door states that it was made in April of this year.
I did all the ground work and install and had my first fire in August. In October the front door fell off. I called the distributor and he said it was my fault that
I had lengthened the chain out too much. Well the chain came from the factory pre-cut to it's full open position. I contacted the factory with no offer of a repair of any kind. Luckily I have a mig welder and welded the hinge back on. I am still trying to get paint to repaint the hinge.
I am also trying to get information on how the controller works and why the alarm light comes on. (PS the light did not work, at least the book comes with passable schematics and I wired it according to the schematics and it now works). No can seem to tell me how this is programed in the controller. I would also like to lower the heat setpoint for summertime domestic hotwater use, however no will again tell me if I can do this. I pray to go the controller never fails.
The lifetime warrantee appears to be a big hoax. Just my experience so far with this company!!
