Author Topic: standard questions...  (Read 19491 times)
Scratch
  • OWF Model: CB6048
    • Edge Metalworks
« on: January 05, 2009, 03:53:48 PM »
Because I want to see this forum grow in members and input, I'm thinking of topics to talk about.
So I thought about some standard questions that might pop up between two OWB owners sittin' down for coffee.
1. What brand OWB do you have?
2. How long are your burn times?
3. How full do you fill it?
4. What type of wood you burn? (pallets, scrap millwork, oak...)
5. How many sq ft of floor lines do you heat?
6. How many sq ft of home space does your furnace heat (that the OWB feeds)
7. What else do you heat? (pool, hot tub, water heaters, coffee maker...)
8. Type of home? (older construction, poor insulation, lots of drafts... )
« Last Edit: January 05, 2009, 04:07:08 PM by Scratch »
Hudson, WI
Scratch
  • OWF Model: CB6048
    • Edge Metalworks
Re: standard questions...
« Reply #1 on: January 05, 2009, 03:58:42 PM »
Here's mine:
Central Boiler 6048
15-18 hours
Pretty much full as I can get it.
Mostly oak, alot of 12" and up rounds.
1900 SF in the basement, 576 in the garage.
About 4800 SF total for the home and added on hair salon, 2 furnaces. (the basement 1900 is included in that number)
Soon to be 1 standard water heater.
10 year old Dome home, good insulation but a few drafts by certain windows.
« Last Edit: January 05, 2009, 04:06:53 PM by Scratch »
Hudson, WI
Dirtslinger
  • OWF Brand: Woodmaster
  • OWF Model: 4400
« Reply #2 on: January 05, 2009, 04:13:27 PM »
Wood Master 4400
forced air with heat exchanger
12-18 hour burn
Half full
Mostly oak,maple all round no splits
No floor lines yet
3000 sq feet for now building 28x32 garage in spring with in floor heat
Hot water heater will be hooked up soon
Newer home 8 years old great isulation
Dirtslinger
Brockway, PA
« Reply #3 on: January 05, 2009, 04:30:32 PM »
    Home made
     12 hours or more
     depends on the weather report, from stuffed full to  just turning the ashes and a couple of blocks
     100% dead elm cut and cured at least one year and stored inside...(very very very little smoke)
      (allthough i still have a stack in my shed of mixed hardwood that is 8 feet wide, 6 feet high and 40 feet long....just in case)
    only  an added on basement of 20 x 24
     1800 sq. ft. home (decently insulated as it is over 100 eyars old but iadd insulation every chance i get
      and a 30 x 40 shed that i keep about 45 unless im out there working then i crank it
    Domestic water of course
     house is over 100 years old storey and 1/2 brick decently insulated but room for improvement
Jason
« Reply #4 on: January 05, 2009, 06:20:42 PM »
Here's my list:
1.  I have a Hardy H5.  I first fired it up for New Year's Eve 2007.
2.  I get roughly 12 hour burn times with good wood on cold days.  Probably a bit more, really.
3.  I always fill it to the top.
4.  I use whatever wood I can get.  This year I lucked into a couple cords' worth of dry seasoned ash, oak, and cherry   that   was mine for the taking.  Just needed cut to length and split.  I also got hold of a bunch of green pine that I started burning the day the trees came down.  Plus there's also whatever I find right here on the farm, mostly dead elm.
5. I don't have any floor lines.
6. The house is somewhere in the neighborhood of 1200 square feet.
7. That's all we heat right now, but we got a big enough furnace that we can heat a garage or something should the need ever arise.
8. We live in an old brick farmhouse.  Most of it is just brick-no insulation at all.  We've replaced most of the windows in the last couple years and when we redid our bedroom last year we put up studs and 1" blue board.  It really makes a heck of a difference in that room.
 :post:
Jason-Pittsburgh, PA
RUGERGUNZ
  • Central Boiler 6048
« Reply #5 on: January 06, 2009, 05:25:17 AM »
1.  I have a Central Boiler 6048.
2.  24hrs+  I add a couple sticks twice a day, but have let it go as long as 36 before I got nervous the fire would go out.
3.  I stuff it, just as much as I can get in there.
4.  Burning broken pallets when I can get them.  Most of my wood is between 5-10years old, softwood, been sitting on the ground and is very wet.
5.  No floor lines.
6.  2100 sq ft.
7.  {Edited to add that I also heat all my DHW}
8.  4 year old double wide trailer.  Very well insulated.  Custom skirting, pressure treated stud wall covered with pressure treated 1/2" plywood, then tyvek and matching vinyl.
« Last Edit: January 06, 2009, 11:28:26 AM by RUGERGUNZ »
PhinPhan
  • OWF Brand: WoodMaster
  • OWF Model: 4400
    • Outdoor Wood Furnace Info
« Reply #6 on: January 06, 2009, 10:44:47 AM »
    - WoodMaster 4400
    - 12 to 18 Hours
    - I only put 3-4 pieces of wood in mine which only makes it about 1/4 full.
    - I am mainly using: oak, black cherry, walnut, locust, and sycamore.
    - None
    - About 1700 or so.
    - Domestic Hotwater
    - Older home about 25-30 years old, very poor insulation and several drafty spots.
Pomeroy, OH
WoodMaster 4400
jon d
« Reply #7 on: January 06, 2009, 11:02:17 AM »
-Central Boiler 5036
2. How long are you burn times?
-12-14 Hours
-1/2 to 3/4
4. What type of wood do you burn?
-oak, locust-whatever's dry
-none
6. How many sq ft of home space does your furnace heat?
-2000 home 900sq ft shop
-Domestic Hotwater
8. Type of home?
-10 yr old home 5 yr old shop, both pretty well insulated
jon d
Hawesville, Kentucky
Central boiler 5036 installed in 09
pdboilermaker
  • www.princesspetitepoodles.com
    • Princess Petite Poodles
« Reply #8 on: January 14, 2009, 11:11:35 AM »
1. What brand OWB do you have?  Woodmaster 4400
2. How long are your burn times?  So dependant on weather and wood but on average 8-12 hours when filled
3. How full do you fill it?  Full in the morning before work, full in the evening before bed.  In between home from work and bed time fillings depend on how naggy the wife is
4. What type of wood you burn? (pallets, scrap millwork, oak...) - Mostly maple, pine and telephone poles
5. How many sq ft of floor lines do you heat? air/air exchanger in upstairs and downstairs furnace
6. How many sq ft of home space does your furnace heat (that the OWB feeds) 4200
7. What else do you heat? (pool, hot tub, water heaters, coffee maker...) domestic hot water
8. Type of home? (older construction, poor insulation, lots of drafts... )  100 years old r-19 in walls, r-19 in crawl space, r-38 in attic.  BUT NO WIND BREAKS UNTIL MY TREES GROW
Woodmaster 4440, Sthil ms310, Jeep Wrangler to pull home the wood, Noritz tankless water heater, smart car
aquathermuser
« Reply #9 on: January 16, 2009, 08:33:38 AM »
     Aqua Therm 345st
     10 to 15 hours in this latest cold western ny weather
     Full. I have a 54" firebox and the majority of the wood i burn is 24" long and 48" long
     Mostly all seasoned -ash, sugar maple, cherry, ironwood. Occasionally I add in some poplar.
How many sq. ft. of floor lines do you heat?
     4700sq. ft. See next questions.
How many sq. ft. of home space does your furnace heat?
     2600sq. ft.
What else do you heat (pool, hot tub ect)
     Domestic hot water, 30 x 50 shop radiant floor heat, house attached garage, full basement
Type of home?
     New build, 3 years ago.
Some clarifications-The aqua therm is a dual pump system.  One pump runs the pole barn shop. This is fully insullated with 3 garage doors also insulated and 10'ft ceilings.  Radiant in the floor and heats the hot water.  The shop is set at 50degrees and when we are out there raise it to 55 to 60 depending.
The attached garage we keep at 55degrees, the basement has radiant heat in the floor but we dont use it much at all. The house my wife likes it warm so it kept at 71 to 72 ish.
