Author Topic: Corrosion Problems!  (Read 11287 times)
MyLeakyWoodDoctor
  • MyIcyLeggedWoodDoctor
Corrosion Problems!
« on: January 06, 2009, 09:50:39 AM »
Oh Man!
Can anybody give a straight answer on this!
I have had two stainless steel Wood Doctors corrode threw in under 5 years!!!
-I'm putting the Wood Doctor boiler treatment in regularly monitoring to maintain good PH as advised!
-I got the entire unit grounded as advised!
-I even placed a standard Hot Water tank anode in my system before I was advised . . . I was a step ahead of the game here!  I shouldn't even need an anode, as black iron, I have been informed by a chemical engineer, is sacrificial to stainless steel and therefore should corrode away first!  My anode is really there to protect my black iron!
-Piping examples provided when I purchased the furnace show black iron piping so this can't be wrong!
-It looks to me that the welding method used to build my Wood Doctor in the first place may have altered the stainless Steel making it susceptible to corrosion along the weld lines!!
What's going on?
« Last Edit: January 18, 2009, 11:28:01 AM by MyLeakyWoodDoctor »
MyLeakyWoodDoctor
Re: Corrosion Problems!
« Reply #1 on: January 15, 2009, 05:13:03 PM »
Another eye opener is stagnate water pockets!
You have to maintain circulation in your open system all the time to prevent pockets of stagnate water from forming.  Inside these pockets corrosive electrolytic loops can activate right on the metal plating.  These tiny corrosive reactions are virtually isolated from any boiler treatment or anodes you may have installed and if not broken by some level of circulation can eat a neat little hole straight threw the plate.
Do any of these dealers tell you that in the off season (summer) you still have to maintain circulation in your boiler and lines?
Am I right here or what!
I can't keep the water in my Wood Doctor!  :'(
« Last Edit: January 22, 2009, 11:07:25 AM by MyLeakyWoodDoctor »
MyLeakyWoodDoctor
« Reply #2 on: February 11, 2009, 02:12:24 PM »
I'm going to post up what Wood Doctor advises for boiler treatment!
What they were asvising before I had two of their stainless boilers corrode through on me!
And what they're advising now!
But before I do that  ....
Eyes Wide Open!  :o
Here is an very interesting blurb I just received from a friend!!
Can't say I know for sure if it is all correct, but it sure sounds feasible to me!!
How Wood Doctor can just sell customers an OWB and then just leave them in the dark about all this stuff, I do not know???
Well hey,  they are the ones warrantying the durability of their products against corrosion among other things, so they're actually the ones on the hook to fix these leaking beast, or so you would think!!  :bash:
My friend says the following in regard to my . . .
           "Corroded Leaking FULLY WARRANTIED Heavy Gauge Stainless Steel WOOD DOCTOR Furnace"
I would venture to suggest, that they may be using 406 stainless as it welds up good with normal steel panels.  However, it also has the characteristic of creating galvanic cells within itself if it lays submerged in still brackish water (freshwater with higher then normal chloride levels).
Are you leaving your system full in the summer when not in use and have you tested water for chloride levels (salt).  It could be that you are using system in the summer too, but you are not getting enough demand to keep water circulating enough.   Whatever the case, it could be that there are pockets of still brackish water forming galvanic cells next to the stainless!
Unless you are regularly blowing down (draining boiler bottom liquid/sludge out under pressure) and topping up with new water you will over time have chloride build up to dangerous levels (levels high enough that the boiler water becomes an electrolyte and allows galvanic cells to form).  Then away goes the iron in your stainless steel alloy and oops there is a hole.  This will occur mostly near the bottom of your boiler where salt concentrations will be highest!
Monitoring PH levels is good, but PH only helps reduce corrosion by keeping water slightly alkaline. Unfortunately, even alkaline water becomes an electrolyte if chloride (salt) PPM get high enough.
Desired level of chlorides should be around 15-25 PPM, but practically you would probably have difficulty keeping it between 50-75 PPM.
You need to test water with silver nitrate chloride test kit to get PPM.  You will likely find that you will need to start draining water regularly to keep chloride levels down. You are shooting yourself in the foot by running the same old soup in system forever, or in this case until it cuts it's own drain holes and runs out on the ground.
In these open systems, boiler water will only continue to build in chloride content as pure water is boiled off (concentrating the soup) and then new water containing even minute levels of salts is added!  That is why boiler water neutrality is controlled by controlling it's dissolved solids (salts etc.).
You don't have to re-invent the wheel here, just trust the accepted methodology. The idea is to reduce the capability of your water to conduct current, thereby reducing corrosion caused by galvanic cells (dissimilar metal molecules next to each other in your stainless steel alloy mix).  Again this is relative, but basically dissimilar metals that are fused together in an alloy create there own electric circuit (or electron flow), this is how thermal couples work.  Anyway, in a mixture (an alloy) an electrolyte is also needed to allow this electron flow to occur (like a battery).  Reduce the strength of the electrolyte and you will reduce electron flow and thereby reduce corrosion!
Please, someone with some additional knowledge about this subject offer us some more insight!  ???
Are there OWB dealers out there telling there customers they need to flush their furnaces on some kind of regular basis, or what?
Did you all notice this particular sentence . . . "You don't have to re-invent the wheel here, just trust the accepted methodology"
I'm putting a pic here showing those holes in my Wood Doctor heavy gauge stainless steel furnace . . .
Leaky  :'(
« Last Edit: February 21, 2009, 01:39:25 PM by MyLeakyWoodDoctor »
MyLeakyWoodDoctor
« Reply #3 on: February 22, 2009, 02:11:52 PM »
Ok,
This is what Wood Doctor said to do for the first 5 years I have dealt with them.  In these 5 years I have had two (2) heavy gauge stainless steel OWB corrode through on me!
I'm going to try for two pics here of my original instructions and boiler treatment!
Leaky  :-\
MyLeakyWoodDoctor
« Reply #4 on: February 22, 2009, 02:16:13 PM »
All right,
This is what my most recent shipment of boiler treatment says to do!
It doesn't seem like they have changed their boiler treatment any, yet now I supposed to treat to an entirely different PH range!
What's going on here?   ???
What are other dealers telling their clients, I wonder?
Leaky  :'(
R W Ohio
« Reply #5 on: February 22, 2009, 03:10:12 PM »
Before Hawken Energy made the change of water treatment, they wanted PH of 7.5 to 8.5. Now with the new treatment I have to send a sample in and the lab lets me know if I need to add any treatment. They say I do not need to check it myself. Go figure.
« Last Edit: March 02, 2009, 05:11:54 AM by R W Ohio »
R W Ohio
Canal Fulton,Oh.
bruey
« Reply #6 on: October 29, 2010, 10:49:22 PM »
r.w. did you ever get an answer about draining your stove every year?  or what the problem is causing the rust through?
Newrichmond, Ohio
