Author Topic: wood master 434  (Read 39739 times)
pintopaul
  • OWF Brand: wood master
  • OWF Model: model 434
wood master 434
« on: November 09, 2011, 05:47:05 PM »
is the any 434's still in use? thanks
johnsdeere
Re: wood master 434
« Reply #1 on: November 16, 2011, 12:35:51 PM »
Yes I have one, upgraded to a 3300 door and blower.
pintopaul
Re: wood master 434
« Reply #2 on: November 16, 2011, 01:56:38 PM »
how long have you had yours? i just got mine hooked up. i bought it used and so far i love it. what do you mean you switched door and blower? whats the differance between the doors mine has a blower on it. thanks paul
ijon
  • OWF Brand: Portage and main
  • OWF Model: 28-40
Re: wood master 434
« Reply #3 on: November 16, 2011, 06:36:26 PM »
I have a 434 that was made in 1994 still keeping me and mine warm.  Good luck to you.
installed in 2014
pintopaul
Re: wood master 434
« Reply #4 on: November 19, 2011, 10:19:48 PM »
starting to love this thing been going for almost a week now and not a drop of oil used  ..... why didnt i do this earlier.
pintopaul
Re: wood master 434
« Reply #5 on: December 19, 2012, 06:35:21 PM »
well its been a year with my 434 and still no oil used . love it
chokesonsmoke
  • OWF Model: 434
Re: wood master 434
« Reply #6 on: March 20, 2013, 10:02:39 AM »
just bought a house with a wood master 434.  i was wondering how to set the water temperature?  any suggestions, i know almost nothing of this system.
chokesonsmoke
  • OWF Model: 434
Re: wood master 434
« Reply #7 on: March 20, 2013, 10:13:07 AM »
to be more specific:
i have been using the 434 all winter this year with trial & error success.  the system seems to be set up to run in conjunction with a gas furnace.  my gas bill is still higher than i would expect for amount of wood we consume.  i turned gas off to the furnace a few days ago and hoped the 434 would heat the house alone.  i have had trouble getting the water temp from the stove to raise above 90-110 degrees.
dwneast77
    • HeatherWood Gardens
Re: wood master 434
« Reply #8 on: March 25, 2013, 08:43:35 PM »
I think we need more info.  I'm not familiar with the 434 but I can't see any reason why you can't heat your home solely with the wood stove.  First off, has everything been cleaned up good?,  all vents and draft fan and chimney clear and workiing properly??  Can you see the setting of the aquastat??  Usually set around 180 or so.  Also, guys out here would be looking to know what size pump you have feeding the home, location of the pump and the size and length of the water lines.  Also how is it connected to the gas furnace, I assume a water/air HX??, or is it a gas boiler?
The more details you can provide the easier it is to make suggestions.
Eastern Maine (near Calais)
Central Boiler E-2300
Wood Doctor HE10000
Stihl 290 Farmboss
Craftsman 27 ton Splitter
JD 870 Tractor
pintopaul
Re: wood master 434
« Reply #9 on: April 04, 2013, 07:04:14 PM »
is the fan coming on? if not a couple thing to look at. remove the back cover theres a thermostate on the back look what its set at mine is set to turn fan on at 150 off at around 170 but depends on size of house . If the fan comes on make sure the little damper on the front of the door is opening sometimes just alittle wd40 or 3 in one oil works(to get to the fan on the 434 you need to remove the cover on the front of the door) maybe the damper isnt opening thats why its not burning hotter. Hope this helps. Paul
Jared43758
  • OWF Model: C250
Re: wood master 434
« Reply #10 on: December 25, 2015, 08:04:47 PM »
That's stove sounds sick
Stihl MS290
Stihl MS660 Magnum
Husky 21 ton splitter
Southeast Ohio
pintopaul
Re: wood master 434
« Reply #11 on: January 07, 2017, 04:41:42 PM »
replaced my old 434 with a 3300 working great other than the chimney fires, old one didnt do this. someone help explain this. thanks
aarmga
  • OWF Brand: Nature's Comfort
  • OWF Model: NCB-250
  • Central Wisconsin
Re: wood master 434
« Reply #12 on: February 03, 2017, 10:52:18 PM »
Welcome back.  If you have a lot of creosote built up in your chimney it will catch fire.  I do this deliberately once a year before I brush it out.  I stack the stove with clean cardboard light it and keep the ash pan cracked open and let it burn.
Stihl 211 - 16"
Remington Rodeo Pro - 20"
Stihl 661r magnum - 36"
SpeeCo 22 Ton Honda splitter
JD 1025r with FEL
pintopaul
Re: wood master 434
« Reply #13 on: February 05, 2017, 05:34:49 PM »
woods dry 1 1/2 yrs and undercover, hardly and cresote but still getting chimney fires at a loss for explaining it. always does it about a half hour after i fill it , flames probley 2 ft about extended chimney.
aarmga
  • Central Wisconsin
Re: wood master 434
« Reply #14 on: February 05, 2017, 10:39:14 PM »
If I remember correctly that stove used a Dayton blower fan on the front door.  Is there an adjustment on that fan?  My stove uses the same fan and there is a small plate in the rear of the fan between the stove  and the output of the fan.  I noticed mine would throw sparks everywhere when this air adjustment was wide open from the factory.  Just something you could take a look at.  Maybe one of the veterans will chime in that know these stoves really well.
Stihl 211 - 16"
JD 1025r with FEL
