Pages: 1 ... 3 4 [5]
Author Topic: fire dosen't burn hot enough with door closed  (Read 47277 times)
ssr
Re: fire dosen't burn hot enough with door closed
« Reply #60 on: December 05, 2011, 09:24:58 PM »
about to see what the scrapper will give me for the whole thing.lol
ssr
« Reply #61 on: December 05, 2011, 09:26:13 PM »
will trade for a crappy looking one that works good.lol
« Reply #62 on: December 05, 2011, 09:26:41 PM »
the grate is removable .you think i should just build the fire on the bottom of the fire box?i havent tried that one
Yes.
There are a lot of brands that don't have grates at all.
You need to get a coal bed a few inches thick built up when you don't have a grate for it to work good.
ssr
« Reply #63 on: December 05, 2011, 09:29:00 PM »
i will try that one tomorrow.cant get the grate out right now  . hopefully it will work
rosewood
« Reply #64 on: December 05, 2011, 09:34:34 PM »
you do have good wood to burn? and your sure that fan is putting out a good flow of air? that fan is rotating the right way?squirril cage was installed from factory in right direction?
ssr
« Reply #65 on: December 05, 2011, 09:36:34 PM »
was burning oak,running low now.positive the fan is putting out air.
ssr
« Reply #66 on: December 05, 2011, 09:38:57 PM »
getting some hedge shortly.but i still need a good air flow no matter what im burning.
« Reply #67 on: December 05, 2011, 09:40:18 PM »
Is the wood green??  If its wet or green it really makes problems 10x worse
On another note....  I'd rather have dry pine as green or wet oak, you lose over half the available btu if Your burning wood that is not properly seasoned
« Last Edit: December 05, 2011, 09:42:02 PM by Scott7m »
« Reply #68 on: December 05, 2011, 09:42:40 PM »
i think the best thing to try is the idea of removing the grates and just trying the wood without them.
ssr
« Reply #69 on: December 05, 2011, 09:42:55 PM »
its a mix now im just about out,the wood coming is seasoned hedge.the wood i had before was seasoned oak and green bs mixed. will the hedge be to much if i load it half full
« Reply #70 on: December 06, 2011, 07:05:29 AM »
In your stove I have no idea, in a stove that shuts down properly and seals the air out it's no big deal but where we haven't seen any consistency on your stove so far I'm not sure what will happen
Did you ever switch the pump from top to bottom?
Also, if it burns correctly and you have no way of shutting all air off to the stove it should boil over in less than an hour and probably look like a geyser
MattyNH
  • OWF Model: 7300E ; S-275
« Reply #71 on: December 06, 2011, 01:32:52 PM »
Is your stack plugged?.. Not sure how high it is...I had a problem last spring..The very top of my stack was pretty much plugged up..Inch thick of creosote  and the opening was about the size of a golf ball..Like I said It was at the very top of the stack..Rest of the pipe was clean...When it was plugged up..It didn't matter with forced air etc...That fire would not burn like it should when the door was shut....Almost seemed like it was putting itself out when the door was shut..Not to mentioned..Door gasket was all gooed up....
Crown Royal 7300E (2021)
Aqua-Therm S-275 (2006)
Jonsered 2188
Jonsered 2165
Jonsered 2050
Kubota L3800DT
beeman
  • OWF Brand: homemade
« Reply #72 on: December 06, 2011, 05:18:56 PM »
i would try dumping some sand or dirt about 12inches back from the door all the way to the top of the fire greate this way the air has to go up through fire first  easy test
