Pages: 1 [2]
Author Topic: Another Thermostat wiring question  (Read 17389 times)
Re: Another Thermostat wiring question
« Reply #15 on: December 12, 2011, 07:19:46 PM »
Oh, okay. I've never tried that. Interesting, I will have to check that out.
Sconnieman
« Reply #16 on: December 13, 2011, 12:38:17 PM »
Thanks guys, I will try that tonight RSI. If I understand you correctly by removing the wires from the G terminal I won't be able to use the Fan Only feature on the thermostat, correct? That's not a big deal as long as the fan turns on when it calls for heat or ac. Thanks again.
NW Wisconsin
Aqua-Therm E275
Husky 346xp
« Reply #17 on: December 13, 2011, 01:02:36 PM »
Yes, that is correct. If you do want to manually run the fan in the summer you can turn the temperature up on the second thermostat and switch it to heat. It will do the same thing that the old fan switch did.
Tlajd
  • Newbie
  • OWF Brand: Cb
  • OWF Model: 5036
« Reply #18 on: October 08, 2014, 08:05:29 PM »
Thanks a bunch for your post.  I connected those 2 wires together and left the green empty and it stopped turning on my ac. Thanks so much. Really helpfu
L
Pages: 1 [2]
