Author Topic: help for a newbie  (Read 9710 times)
wink
  • OWF Brand: Shaver
  • OWF Model: 165
help for a newbie
« on: December 17, 2011, 07:53:50 PM »
couple of questions guys
How does one know when the water is boiling. I built my first fire around 2pm. The fan finally kicked off around 7ish. The t-stat is the cheapie that came on the unit.
I went out around 8 to top off the tank because this is inital start up and i know the pex lines and EX took some of the water. I noticed steam coming from the top off port on the left side of the stove. When I opened the valve, water kinda shot out from the overflow.
Secondly, when I open the stove to load, a lot of smoke comes out. This is even after I turn off the fan via a switch
Thanks in advance!!
johnybcold
  • OWF Model: Classic E1400
Re: help for a newbie
« Reply #1 on: December 17, 2011, 07:58:13 PM »
What kind of unit do you have I have a cb there is a lever to push before you open the door
old truck
old craftsman chain saw
Polaris Sportsman 500HO
martyinmi
  • OWF Model: Optimizer 250
« Reply #2 on: December 17, 2011, 08:19:12 PM »
Get used to that smoke in your face. Your friends are going to think you changed cologne. To me, it's the smell of almost free money! I have no experience with the Shaver furnace, so I can't help with the other questions. Lots of shaver users here, and I'm sure they'll help ya.
Newholland TZ-25da
30+ Chain Saws
'05 Dodge Diesel
Michigander
TSC 35 Ton Splitter
Bull
  • OWF Model: Rebuilt H2
« Reply #3 on: December 17, 2011, 09:15:13 PM »
I have a hardy but I always open the ash door first and wait a few seconds to open the load door.
Southern Indiana
JBG
« Reply #4 on: December 18, 2011, 05:43:09 AM »
I have only had my water boil one time during the summer but I could tell by the "bubbling"
sound and excessive water/steam coming out the overflow.  As for the smoke,  get used to
it. :thumbup:
Shaver 290
37 Ton Northstar log splitter
beeman
  • OWF Brand: homemade
« Reply #5 on: December 18, 2011, 06:59:43 AM »
you will have a cold full and a hot full the smoke dont stand in front of the door  when i go to fill mine in the morning as i walk by to get some wood i open the door it is prety way cleared out when i turn around mind you at 5:00 am in no herry eny way is it just heat comming off the water just thinking welcom to the post
lugnut
« Reply #6 on: December 18, 2011, 10:23:12 AM »
Mr. Wink,
Regarding the smoke, there are two ways to resolve this issue, well actually three and Beeman touched on number three.  You could install a switch on the right side of the furnace so that you can shut off the fan, if it is running; the other option to avoid the smoke is to slowly open the ash door first.  The very LAST thing you want to do is to open the firebox door quickly...you can receive a "flash" of fire.
So, to summarize:
1) Fan switch install
2) Open ash door...slowly
3) Open firebox door...slowly
Hope this helps...and believe me Mr. Wink, you are NOT alone in your quest to get the Shaver working as it should.  Wink-wink-nod-nod.   ;)
Jerry
aka: lugnut
Jerry
Greenleaf, Wisconsin
Husquvarna 455 Rancher
