Author Topic: I want to share what i have learned  (Read 17467 times)
twain
« on: December 25, 2011, 09:52:37 AM »
I have been burning 4 years. I have a central boiler 6048. I live in West Bygod Virginia. I have a very old, very large house, not insulated very well.
1. I built a wood / furnace totally enclosed room on my garage. I enclosed about half of the unit in the wall. I can also store about 3 cords of wood in the room. I installed a fan in the wall to draw the smoke out of the room. Only above the furnace i used 1" foil backed foam covered with tin. The room has proved very helpful and worth every dime.
2. I keep my wood cut well ahead of time. Seasoned wood will make a big difference in consumption.
3. I burn all wood, but the best i have found is. Osage, locust, hickory, hard maple and red elm.
4. Keep ash out of furnace and stirred. It makes a big difference. Keep in mind i have a central boiler.
5. Place the unit as close as possible ( remember prevailing wind) and buy the good pipe. I bought the single pipe with both discharge and return lines inside, foam filled. Insulate everything you can.
6. Round wood better than split.
7. I load the front section of the unit only. I cut 20"
8. I have a metal wheel barry to take out ashes. Wrap some potatoes in foil and put in ashes and take outside.
My opinion only. May help someone new or just starting.
Treewinder
  • OWF Brand: Shaver
  • OWF Model: 250
Re: I want to share what i have learned
« Reply #1 on: December 25, 2011, 10:09:41 AM »
Welcome in, good info.
I also built a atructure for my OWB, nice to keep wood and tools in also
Ed
Eastern Shore of Va.
Shaver 250
041 056S 056M
MS660 070 084
CS670
CSM-Procut design & Baker 18M
Komatsu D-21-P
Kobuta B-6100
jerkash
  • OWF Brand: Legend
« Reply #2 on: December 25, 2011, 12:34:59 PM »
I'm new to this, but I'm wondering why you say round wood is better than split.  Most posts I have read were split wood burns better.
Thanks
« Reply #3 on: December 25, 2011, 02:18:28 PM »
here are some thougthsi have read on other sites on this subject (are they true i dont know but sound reasonable)  in an epa gasser splits work better as they burn faster and get you the temps needed for the secondary burn (?) rounds last longer so they are giving off less btu per hour (sounds reasonable but i have never measured myself)
in my own home made stove i try and burn mostly rounds i burn anything from 2 inch rounds to 20 inch rounds
i do not have a gasser so  it doesnt matter to me if my blower has to run longer to reheat the water to the set temp as long as it can recover before dropping too low to supply the btu's being drawn.
in an OWB im not sure it really matters?
lets here some more thoughts on this one
« Reply #4 on: December 25, 2011, 05:24:44 PM »
Welcome to the site twain, I agree that split burns faster and hotter and rounds burn longer.
PatrickfromPA
« Reply #5 on: December 25, 2011, 05:52:06 PM »
In my 3.5 years I have learned that rounds last longer, split wood burns too quick. I find myself out there 2 times a day filling the thing up where as when I burn 4 or 5 large 20" rounds I can get 2 days out of it. Split seasoned "mixed hard wood" that you buy by the truckload is 12 hours at a time.  I personally try to keep my wood to a 30-40 lb weight. it makes it easier throwing them into the back. I have a 5 ft long boiler with a 30" door. I hope this help. Hey does anyone have a good chart on which wood works better or a seasoning schedule ?
OWB-wood doctor XL champion series
installed 1-16-2010
uses for my OWB-
heat house/garage- Air condition house/garage-
working on using the seebeck/thompson effect to generate electricity
« Reply #6 on: December 25, 2011, 06:04:19 PM »
i like to season my wood at least 6 or 8 months (but i cut only dead elm so they are partially dried when i cut them) i am cutting now for next winter (i have oak in the shed  that has been in there for 5 years as a badk up in case i cant get to the bush)
as for a chart this one may help?   http://hearth.com/econtent/index.php/articles/heating_value_wood
fireboss
« Reply #7 on: December 25, 2011, 06:42:23 PM »
I to have a cb 6048 this is my 2nd winter[ but i heated my pool with it all summer ] iam finding no diferance between split and not split . i bin sticking with the split it is easier to load and its not that cold here 40 during the day and 25-30 at night
PatrickfromPA
« Reply #8 on: December 25, 2011, 07:05:33 PM »
wow, thanks. Great website thanks for that tip
installed 1-16-2010
uses for my OWB-
twain
« Reply #9 on: December 26, 2011, 04:14:46 PM »
Dang great replys you all
« Reply #10 on: December 26, 2011, 07:27:37 PM »
5TH year of having my OWB..In the dead of winter Im reloading twice a day..I have friends that have CB's, Hawken,Aqua-Them..No matter what twice a day..I like a good mixture of round and split..The problem with straight round wood, is that the wood doesn't fall into the fire like split wood does.. Round wood gets caught up and then theres a hole in the fire..Either way I find no difference split or whole..In burn time... Whole wood just fills the fire box quicker when reloading..
martyinmi
« Reply #11 on: December 26, 2011, 07:31:41 PM »
I agree :post:
Newholland TZ-25da
30+ Chain Saws
'05 Dodge Diesel
Michigander
TSC 35 Ton Splitter
mikenc
« Reply #12 on: December 27, 2011, 07:00:39 AM »
Keep all in the round i can. Rounds seem to last longer. Mine is just the opposite rounds seems to fall down better, split gets stuck to sides. Cut all mine 22'' long. Only load front of stove, and try to load according to demand. I do try to burn only seasoned wood to.
johnybcold
  • OWF Model: Classic E1400
« Reply #13 on: December 27, 2011, 03:28:07 PM »
I am new just fired it up a few weeks ago and I am running halfass until the new CPU comes in but I do whatever is easier which means I only split pieces I cannot pick up
old truck
old craftsman chain saw
Polaris Sportsman 500HO
martyinmi
« Reply #14 on: December 27, 2011, 05:03:23 PM »
I'm not CB's biggest fan, but I'm told by my friends who own their gassers that split pieces or smaller rounds really make them shine. You should get more efficient/less smokey burns with many smaller pieces verses a few large ones. Almost all gasser work that way, unless it is a very large one like the CB 3200 or the P&M 450.
Newholland TZ-25da
30+ Chain Saws
'05 Dodge Diesel
Michigander
TSC 35 Ton Splitter
