Author Topic: Thermostat  (Read 3894 times)
pwdiver
  • OWF Model: CL5036
    • narronseggstra's
Thermostat
« on: January 02, 2012, 06:46:17 PM »
I have a 2 wire thermostat that just cut's my air handler fan on and off, Do you know of a programmable thermostat that would do the same for the boiler , I currently have a honeywell programmable for the heatpump not sure how to use this one with the CL5036 boiler. ::) would like to be able to ramp temp down at night with out doing it myself.
New Holland TC30 tractor
powerdiver6000@aol.com
Ridgekid
Re: Thermostat
« Reply #1 on: January 02, 2012, 07:02:04 PM »
Try the filtrete 3M-50. You can get them at home depot. Another member on this site tried it and it solved his issues.
Re: Thermostat
« Reply #2 on: January 02, 2012, 09:57:08 PM »
Pretty much any thermostat will work. Just get one that uses batteries if you don't have a common wire.
If you only have two wires, put one on the W and the other on the R.
