Pages: 1 [2]
Author Topic: Cold Night - Clear Skies (photo)  (Read 16395 times)
Ridgekid
  • Guest
Re: Cold Night - Clear Skies (photo)
« Reply #15 on: January 04, 2012, 08:52:56 AM »
Yeah it is. Just turn your thermostat down for the heat pump. It should not come on. This way the sump heater on the compressor will stay on too.
« Reply #16 on: January 04, 2012, 09:09:11 AM »
I have a 10kW Generac with Automatic Transfer Switch.  RSI mentioned something about relays which im interested in but I dont have schematics and dont know what components to use.  I would simply like to wire the furnace fan separate from the electric grid in the furnace.
I forgot about that.
see if you have a schematic of your system and post a picture (or email) of it. It is usually located on the back of a cover.
oldchenowth
  • Guest
« Reply #17 on: January 06, 2012, 04:56:42 AM »
Going back to Ridges post, he's right always turn off your main but I put a light on my meter side of the main so when the power comes back on the light pops on and I can turn off the genny.  Put it on a pull chain somewhere it is easy to see and turn the light off when normal power is on.  Yes, I know it is unfused.  But, most if not all, on here are competent enough to be careful when wiring something like this.  My neighbors usually watch when I shut mine off so I guess I am the test monkey.
Pages: 1 [2]
