Author Topic: Pre heated air for draft intake??  (Read 4749 times)
clydem
  • OWF Model: 5036
« on: January 07, 2012, 10:56:55 PM »
Would a OWB  burn more efficiently if the air let in by the draft damper was pre heated somehow?  Possibly heated by the stack gas?
Just a thought,  It comes from 33 years working in a coal fired power plant.
later
Clyde
CB5036    inst: 11/20/11
JD 4600,  G27 IWB
pwdiver
  • OWF Model: CL5036
    • narronseggstra's
Re: Pre heated air for draft intake??
« Reply #1 on: January 08, 2012, 06:28:02 AM »
We do the same thing where I work heated forced draft air means we dont have to burn as much fuel as we would with Ambeint air temp. :)
New Holland TC30 tractor
powerdiver6000@aol.com
« Reply #2 on: January 08, 2012, 06:48:52 AM »
Welcome to the site clydem
mcarter
  • OWF Brand: HeatMasterSS
  • OWF Model: MF5000e
« Reply #3 on: January 09, 2012, 09:15:43 AM »
This is interesting, I opened the rear door of my OWB and felt a good amount of heat in that small space escape out.  I wondered if I was losing heat out of my OWB but maybe it was designed this way to sort of preheat the draft air?
yoder or scott have any input on this?
Michael
MS 460 Stihl Magnum
Husqvarna 345
5 acres
« Reply #4 on: January 09, 2012, 05:17:47 PM »
Yea preheated air should give you more efficiency.   Garn furnaces do this but most do not.
