Author Topic: Temperature settings  (Read 15965 times)
tbone
  • OWF Brand: Heatmor
« on: February 02, 2012, 07:03:32 AM »
What temp differential do you use?  Mine has always been 20 degrees and I have never changed it...just lowered or raised my on and off depending on the weather.  Just curious...always looking to burn less wood.
Stihl pro 360
Honda 27 ton splitter
Ford 350 with hoist
Re: Temperature settings
« Reply #1 on: February 02, 2012, 07:40:24 AM »
Long burns are the cleanest and most efficient.  I run 15 degrees with wood and 8-10 with coal.
ELEproducts.com
« Reply #2 on: February 02, 2012, 09:47:03 AM »
Hello.
Here is a graph  http://burnrite.net/PDF/012812-2.pdf  of what a 5 degree differential does on a day with moderate ambient temperatures ~ 35F.  Adding additional “soak” time only makes the problem worse.  Recovering from the 5 degree differential or 15 degrees! only creates an unnecessary hot fire wasting fuel.  There will not me much creosote or wood remaining.
As you can see, the marked areas are the startup point where huge amounts of belching smoke being emitted.  No wonder why the EPA wants regulations.  Those in close proximity to other residents complain and these stoves are being outlawed with residential zoning laws.
Shawn
ELEproducts.com
« Reply #3 on: February 02, 2012, 11:17:31 AM »
Hi,
Here is a graph of the i723 FIRESTORM, PID controller  http://burnrite.net/PDF/012812-3.pdf  .  This is the low temperature test.  Results are great.
Thanks,
Shawn
BoilerHouse
  • OWF Brand: Home Built
« Reply #4 on: February 02, 2012, 11:19:29 AM »
Hello.
As you can see, the marked areas are the startup point where huge amounts of belching smoke being emitted.  No wonder why the EPA wants regulations.  Those in close proximity to other residents complain and these stoves are being outlawed with residential zoning laws.Shawn
I think the graph would have been more effective if it had been correlated to actual stack emission data, and also compared to short burn cycles vs longer burn cycles.  As it stands I don't find the graph to be very effective.
Muskoka, Ont
« Reply #5 on: February 02, 2012, 11:47:53 AM »
Do not beleive it, I've been around this stuff long enough to know better and everyone here that is experienced has said the same thing.  But I'd your looking to make a creosote bomb, go for it
ELEproducts.com
« Reply #6 on: February 02, 2012, 11:52:58 AM »
The burn cycle, long or short from the factory ON-OFF control with differential, whichever it may be, still leads to erratic control and belching smoke and wasted fuel in the recovery during the beginning of every recovery cycle.  Even with this first series of tests, the neighbors will be very happy.
Thank you for the comments.
Dirtslinger
  • OWF Brand: Woodmaster
  • OWF Model: 4400
« Reply #7 on: February 02, 2012, 12:16:46 PM »
15 for me seems to work just fine not a lot of smoke and no build up. So put that in your graph and smoke it. ;D
Dirtslinger
Brockway, PA
martyinmi
« Reply #8 on: February 02, 2012, 01:43:22 PM »
Shawn,
   Do you have any videos that you can post? I need to see one in action.
   By the way, my guinea pig offer still stands, and I will give honest reports to all on this site. I still believe your product could possibly work well on gassers if tweaked properly.
Newholland TZ-25da
30+ Chain Saws
'05 Dodge Diesel
Michigander
TSC 35 Ton Splitter
« Reply #9 on: February 02, 2012, 02:00:57 PM »
Ele, come to my house...  Run my stove and see if you can make it smoke, u may on the intial loading but there is noooo "belching" of smoke and rarely is any smoke visible..
You can visibly watch the fire and the hotter it is the cleaner it burns which means not as much fuel is being wasted..
How about some real evidence?  I don't care what a chart or graph says, you can twist stuff like that. To show anything
Take marty's offer, he is your only chnce for bringing legitimacy to this product
fireboss
« Reply #10 on: February 02, 2012, 04:09:39 PM »
Scott, I am confused which is better long burns or short ? My cb only allows a 10 degree differance.
« Reply #11 on: February 02, 2012, 04:12:56 PM »
You have the love control or one like it that's already set at 10 degrees.....
I have found it beneficial in my experimenting that longer burns result in more efficient burns, less smoke, and less creosote.  No reason to tell you that you need something u don't, just free advice.  Keep in mind if you use a control other than what your stove comes with you void your warranty
tbone
« Reply #12 on: February 02, 2012, 04:17:01 PM »
thanks scott, going to try 15 and see how that works....you think 20 is a little high?
Stihl pro 360
Ford 350 with hoist
Bill G
  • OWF Model: Opt. 250
« Reply #13 on: February 02, 2012, 04:26:38 PM »
    Wishing for "more power to ya!!", but your test was conducted over 1 hr and 9 minutes according to time line on your graph.
    How about conducting a test for 9 days and 1 hr maybe.  Just curious as to why only 105 deg?  Does that not keep oxygen in the furnace water?
    I hope your on to something, but cresote is nothing but trouble and it just seems that without a good hot burn cycle, it is going to accumulate.  I think a smoldering fire will produce creosote, wether you steadily maintain 105 deg water or 185 deg water.  The wide open burn has to work/aid in burning off accumulated creosote deposits.
    Then again, suppose you were just running testing to see if furnace temp, could be maintained steady.  Appears to successful, but is it conducive to clean operation of the OWB?
    Keep at it, as if someone like you wasn't willing to step out on a limb, we would be less educated on what works and what don't.  But, constant questioning from the likes of us on the forum shouldn't get to you.  We ask questions, we will forever have "doubts", only because we/I do find it all interesting.
Bill
Stihl saws
Homegrown splitter
'10 3500 Dodge Cummins
NE PA
« Reply #14 on: February 02, 2012, 04:30:27 PM »
That's another part of the equation that's missing, good point bill G, at such low temps the o2 level in the water would be crazy high....
