Author Topic: shop heat  (Read 27377 times)
duke
  • OWF Model: MF5000
shop heat
« on: February 21, 2012, 08:18:51 PM »
Can anyone tell me what size heatexchanger i need for a 30x40 shop 10' walls?
06 Duramax
08 Polaris Ranger XP
MS 310
28 ton Swisher
AirForcePOL
  • OWF Model: G400
Re: shop heat
« Reply #1 on: February 22, 2012, 07:57:20 AM »
Is it insulated well?  I have been looking at these Dragon Breath 100K BTU for my 36x45.  This website says figure for 4,000 btu per 100 sq ft.
http://www.altheatsupply.com/shop-by-needs/heat-exchanger/unit-heaters/dragon-breath-heater-100-000-btu.html
Athens, Illinois
Dealer for HeatMaster SS
Stihl MS 290
Troy Bilt 27 ton splitter
NewToIt
  • OWF Brand: Wood Doctor
Re: shop heat
« Reply #2 on: February 22, 2012, 08:27:03 AM »
What ever size you go with, I would consider a "squirrel cage" style blower.  That is what I have in my shop, because I learned from a buddy's shop how loud those regular fans can be.  The "squirrel cage" moves more air with less noise, IMO.
Re: shop heat
« Reply #3 on: February 22, 2012, 08:37:23 AM »
No doubt the squirrel cages are much quieter
duke
  • OWF Model: MF5000
Re: shop heat
« Reply #4 on: February 23, 2012, 07:26:26 AM »
Thanks, for replys, and yes shop will be insulated well, will be built this spring. My dealer said it would be $1500 for him to install, so i am looking for cheaper option. I have a buddy with back hoe helping with plumbing shop so ii can burry lines myself. Thanks for link to website too there stuff seems pretty reasonable on price.
06 Duramax
MS 310
28 ton Swisher
koutsman
  • OWF Brand: Legend
  • OWF Model: 6180
Re: shop heat
« Reply #5 on: February 23, 2012, 07:45:20 AM »
Can a guy get a squirrel cage fan and mount it to a water to air hx that mount's to the ceiling??  If so where???   I have the regular style fan that blows through the hx and it is noisy, real noisy.
Kouts, Indiana
Legend 6180 - Installed 11/09
STIHL Farm Boss 20"
duke
  • OWF Model: MF5000
Re: shop heat
« Reply #6 on: February 23, 2012, 08:11:32 AM »
Is the dragon breath similar to squirel cage you guys are talking about?
06 Duramax
MS 310
28 ton Swisher
Re: shop heat
« Reply #7 on: February 23, 2012, 08:12:06 AM »
Yes you can.  There a bit pricier though.
Re: shop heat
« Reply #8 on: February 23, 2012, 08:12:35 AM »
No, they are very noisy units
hddmax66
Re: shop heat
« Reply #9 on: February 23, 2012, 09:28:24 AM »
this is what i use. works great and the price was right
http://www.freeheat4u.com/catalog/item/6944283/6945972.htm
hddmax66
Re: shop heat
« Reply #10 on: February 23, 2012, 09:35:18 AM »
I have a 30x30 with 9 foot walls. That heater heated my garage all season with no insulation and kept up just fine. On the low speed setting as well
« Last Edit: February 23, 2012, 09:36:56 AM by hddmax66 »
NewToIt
Re: shop heat
« Reply #11 on: February 23, 2012, 12:34:45 PM »
hddmax....
Yep, that is very similar to the one I have.  I rarely take it off low speed.  I switch it to medium if I want to raise the temp. quick, but after that I switch it to low speed, and the blower just cycles on and off when calling for heat.  Have only put on high speed a couple of times, and mainly just to say I did.... never needed to.
AirForcePOL
  • OWF Model: G400
Re: shop heat
« Reply #12 on: February 27, 2012, 07:36:17 AM »
hddmax and newtoit,
Do you guys have any pictures of one of these installed that you could share?  I'm just kind of curious as to how much space they take up and what the entire thing looks like.  They don't have a very good picture on that website.  Thanks!
Athens, Illinois
Stihl MS 290
NewToIt
Re: shop heat
« Reply #13 on: February 27, 2012, 07:58:54 AM »
I'll try to snap a couple pictures this evening.
And just to emphasize what I said earlier, IMO there is no comparison to my squirrel cage blower vs. a buddy's fan style unit.  Might be a little more money, but well worth it.  Don't want you to make the same mistake he did.
Mark
Re: shop heat
« Reply #14 on: February 27, 2012, 08:36:36 AM »
If you want a squirrel cage blower I would just build it instead of buying a complete unit. You can get a blower for almost nothing because every old junk gas furnace has one.
Also by using a squirrel cage blower you can make it wall mount if you want to. I built a small one for a 24x24 room with stuff I had laying around. Most of it is wood and it works real good.
