Author Topic: Warm weather...  (Read 6956 times)
MNRVGuy
  • OWF Model: ML 30
Warm weather...
« on: March 12, 2012, 07:53:29 PM »
With the warm weather here in Minnesota I am loving the wood consumption (or lack there of) but I am not liking the build up of creosote! How am I ever going to clean that out of my P&M?
Portage & Main ML 30
Husqvarna 455 Rancher & 61 Rancher
Huskee 22 ton spliter
Polaris Sportsman 500
EZGO TXT Golf Cart
Cub Cadet 1050LT
Princeton, MN
Re: Warm weather...
« Reply #1 on: March 12, 2012, 08:48:35 PM »
Expand your temp differential to like 20 degrees , it should make a longer hotter burn ad get rid of some of it for u
Also, don't put anymore wood in it than you have to have
lugnut
Re: Warm weather...
« Reply #2 on: March 14, 2012, 11:22:29 AM »
So, if he expands the differential temp by 20*, does that mean once it reaches its designated shut off, that it will sit and idle until it reaches the 20* diff and fires back up?   ???    Seems one would want a shorter diff so that the fire doesn't sit and idle....this to me is what causes the creosote, but then again...I am still new at this wood burning stuff.   :bash:
Lugnut
Jerry
Greenleaf, Wisconsin
Husquvarna 455 Rancher
Re: Warm weather...
« Reply #3 on: March 14, 2012, 12:17:27 PM »
Lug, little short fires don't get hot enough to burn creosote from the walls of thue stove.  If your fan only runs 5 mins at a time the internal temp of the firebox don't get where it needs to be, as if it burns 45 minutes it will be roaring inside burning everything up.
It may in fact create more creosote during those longer idle times, but I can't tell.  Because when it cycles it gets hot enough to burn it all out...
Close differentials are horrible for creosote, remember that ele product guy that wanted to keep his stove within 1 degree at all times, all the experienced members on here told him he was building a creosote factory
woodman
  • OWF Brand: hawken
  • OWF Model: he1000
Re: Warm weather...
« Reply #4 on: March 14, 2012, 07:06:09 PM »
Yep I keep a 30* diff all season long. Even with these warm temps I don't have any creosolt issues.
