Author Topic: How much did your OWB cost?  (Read 11869 times)
Jackman
« on: April 08, 2012, 12:29:59 AM »
 I don't have a OWB but am considering a Heatmor OWB, have not yet to talk to a sales man so have no clue what the big numbers are, any info is appreciated.
yotehunter66
  • OWF Brand: Woodmaster
  • OWF Model: 4400
Re: How much did your OWB cost?
« Reply #1 on: April 08, 2012, 04:46:37 PM »
$125,000. It came with the house we're buying. :D
Husky 372xp 24"
Makita DCS520i 20"
Poulan 2300 18"
Troybilt 27 ton log splitter
tjdobbs
  • OWF Model: Classic 5036
  • 1st Fire - September 20, 2009
« Reply #2 on: April 08, 2012, 06:09:40 PM »
$9,400 got me a CB 5036, 65' of pex insulated, all the copper for the DHW and the heat exchanger.  It also came with a cement slab laid down under the delivered stove.  Pump and all hardware also, with all of the labor done by myself.
I have heated each of the first three years with eight cords of hardwood, accurately measured.  Not including my labor, the stove will pay itself back in 2015.  It is easy to not count the labor as cutting the wood is so much fun!
-Tall Tom
8 cord mixed un-split hardwood per year cut to 33 inch stovelengths.  2000 sq ft with Sidearm DWH.
Jackman
« Reply #3 on: April 08, 2012, 06:53:43 PM »
 Dobbs , Thanks we are just getting started here, much to learn and was think around 11,000 to purchase and install.
mgw44
« Reply #4 on: April 08, 2012, 07:29:02 PM »
$10,000 for all parts, boiler and wood splitter.  I did the installation myself.  Empyre Pro Series 100.  80 feet of insulated pex.
mgw44
swede
  • OWF Brand: shaver 165
« Reply #5 on: April 08, 2012, 08:11:49 PM »
New Shaver 165.  90 ft. of Badger 5 wrap 4 line pipe.  18x18 Heat exchanger plus all fittings and the uninsulated pex for indoors to the HX and hot water heater.  Self installed for just under $4300.00
the smoke don't mean its broke
Trint
  • OWF Model: ml 30
« Reply #6 on: April 08, 2012, 08:19:22 PM »
About $6,900 for the stove and around a $1,000 for pipe and install parts.  Potage and Main unit though
North Central Ohio
walkerdogman85
  • OWF Model: H-4
« Reply #7 on: April 08, 2012, 08:50:35 PM »
9600 hardy h-4 installed total package 50 feet from house
Michael West
Central Ohio
ijon
  • OWF Brand: Portage and main
  • OWF Model: 28-40
« Reply #8 on: April 09, 2012, 04:26:55 AM »
How many square feet are you heating, and how do you like your Portage and Main?
installed in 2014
Trint
  • OWF Model: ml 30
« Reply #9 on: April 09, 2012, 05:25:22 AM »
I am heating about 2000sqft of poorly insulated circa 1860s farm house.  I like the unit so far will burn anything I put it, have only had it since Sep.  Freatures that lead me to portage and main were the forced draft, ash pan, and heat exchanger.  I have to do some additional insulation work on the house however as I burned close to six cords even in this mild winter.
North Central Ohio
« Reply #10 on: April 09, 2012, 06:24:16 AM »
 I am a Heat Master Dealer and the current prices start at $6,600 for furnace, parts and labor and they go up from there depending on what model they buy. Normally I can install a furnace for under $8,500 to almost any home. Heat Master and Heatmore are both built out of 409ss so hopefully this is a good set of numbers to compare to.
ijon
  • OWF Model: 28-40
« Reply #11 on: April 09, 2012, 03:19:57 PM »
I am heating about 2000sqft of poorly insulated circa 1860s farm house.  I like the unit so far will burn anything I put it, have only had it since Sep.  Freatures that lead me to portage and main were the forced draft, ash pan, and heat exchanger.  I have to do some additional insulation work on the house however as I burned close to six cords even in this mild winter. They look like they are really built well. Their is a dealer in Brown City, Michigan. I'am going to check them out.
installed in 2014
