Author Topic: Cutting firewood  (Read 9582 times)
brohnson
Cutting firewood
« on: August 19, 2012, 03:01:27 PM »
I know there has to be a quicker way to trying to get your firewood all cut to the same size. How do you all do it? Please share your tricks to this newbie.  :thumbup:
HandyMark
Re: Cutting firewood
« Reply #1 on: August 19, 2012, 07:25:44 PM »
I used to try to make it pretty then I realized I am going to burn it. Use a point on your saw as a reference for a while and then just start eyeballing it. You will get it within a couple of inches before long. I seem to have an issue when I cut smaller branches though. They always come out longer. Also check out this if you really want perfection. http://outdoorwoodfurnaceinfo.com/forum/index.php?topic=2127.msg19278#new
« Reply #2 on: August 20, 2012, 03:46:09 AM »
 I use tape and chalk.. I mark as many as I can on the grapple load..Cut the marked ones then i stack the cut logs out of the way so I will always have a clean area to mark and cut more..I do u my saw to for measuring as well..I dont use that tool posted by handymark..
clydem
  • OWF Model: 5036
« Reply #3 on: August 21, 2012, 01:47:09 PM »
I use one of these    works great!
http://www.chainsawsdirect.com/Mingo-265/p3884.html
CB5036    inst: 11/20/11
JD 4600,  G27 IWB
ThatGUY
  • OWF Model: eClassic 2400
« Reply #4 on: August 21, 2012, 02:32:15 PM »
I always just use a cheater stick (aka a small branch) that I would cut to the desired length for firewood (formerly 16" now 24", went from indoor wood stove to outdoor boiler).  Then after an hour I would throw the stick away and cut it like HandyMark - eyeball it  :thumbup:
HandyMark
« Reply #5 on: August 21, 2012, 05:12:22 PM »
When I get a big enough building built I am giving up on stacking my wood so I don't care what the length is as long as it fits in the boiler. I plan to have a lean to on the back of the barn I want to build with the nose of the boiler inside. Planning for a concrete knee wall between the barn and lean so I don't have to worry about bending up the siding shoving wood around with the bobcat. I know it will take longer to dry but with the surplus I have now I should stay two years ahead and give it enough time even under less than ideal conditions.
peacmar
« Reply #6 on: August 24, 2012, 05:37:22 PM »
I use my bar as a guide, 18" bar makes 18" pieces or close enough. Do it enough you'll get an eye for it eventuality.
