Author Topic: Piping a Buderus radiant panel  (Read 9240 times)
Local4fitter
  • OWF Model: E-2400
« on: September 04, 2012, 08:27:14 PM »
I am installing a Buderus radiant panel in a finished room in the basement. Looking for the most efficient way of doing so. The heat guru at a local supply house told me to tee off the supply to feed the radiator and then tee into the return (2 pipe system). Another option is a single pipe system, either in the supply or return line I could tee off to feed the radiator then return out of the radiator back to the same line. I was told to add a ball valve between the tee's to throttle back flow and force water through radiator. These tee's will be coming off a 1 inch pex loop from a new OWB 100 ft. away with a taco 009 pushing the water. If anyone has a similar setup please comment I don't want to do the install and find out I won't be getting proper flow. Thanks Doug
muffin
Re: Piping a Buderus radiant panel
« Reply #1 on: September 05, 2012, 09:04:43 AM »
The tees and valve will certainly work, but give you no thermostat control.  Did you want that?
Local4fitter
  • OWF Model: E-2400
« Reply #2 on: September 05, 2012, 07:18:58 PM »
The radiator has a thermostatic head on it that controls the flow of water. That's the beauty of these radiators, I dont need a seperate pump, thermostat, and controls. So you think the single pipe setup will work? Have you used this setup? Which line would you use?
muffin
« Reply #3 on: September 06, 2012, 11:40:24 AM »
If that is the case and it simply controls the flow, and doesn't shunt the water around itself, then you do not want to put a valve in the main line as this will simply restrict the entire main line when the radiator is off.  You can try a simple TEE, putting the radiator on the straight through path and hope you get enough flow.  Not sure what else to do other than maybe a pump.  You would have to control it with the radiator some how though.
Local4fitter
  • OWF Model: E-2400
« Reply #4 on: September 06, 2012, 06:14:08 PM »
I like the idea of feeding the radiator straight through the run of a tee on the supply. I am bringing 1 inch pex into the house when I get to my mech. room I will add a 1 inch tee, the branch will feed my indoor boiler. Coming off the run of the tee I will reduce to 1/2 inch add a ball valve and feed the radiator. Water, pumped or gravity fed will take the path of least resistance. The radiator will take what little water it uses through a 1/2 inch line and the indoor boiler will get all the rest. Does this sound like it will work? Any comments welcome.
johnybcold
  • OWF Model: Classic E1400
« Reply #5 on: September 07, 2012, 08:08:31 AM »
I am going to look this rad. Up sounds like a good fit for my garage
old truck
old craftsman chain saw
Polaris Sportsman 500HO
muffin
« Reply #6 on: September 10, 2012, 09:18:52 AM »
Sounds good.  Let us know how it turns out.
Local4fitter
  • OWF Model: E-2400
« Reply #7 on: September 26, 2012, 07:13:24 PM »
Update:  I have my owb piped and it has been running for a week now. I ended up piping the radiant panel with a venturi on the supply and another on the return. It works great! Now I just need some cold weather to put everything to the test.
Jack72
  • OWF Model: E-1450 (11)
« Reply #8 on: September 27, 2012, 08:01:43 PM »
Can you post a picture of you're heater           Thanks Jack
Chevy 2500 HD 13 Duramax
Stihl 046 036 009
Northern Tool 25 ton Splitter
