Author Topic: OWB Loading door bolt replacement  (Read 13712 times)
R W Ohio
« on: March 14, 2009, 01:58:44 PM »
Because the hinge bolts had egg shaped the holes in the loading door,I drilled out both sides of both hinges and pressed in bronze bushings.I then used shoulder bolts and nylok nuts.Now if the bushings wear all that needs to be done is to push out the worn bushings and press in new ones.
RW
« Last Edit: March 14, 2009, 02:58:45 PM by R W Ohio »
R W Ohio
Canal Fulton,Oh.
Re: OWB Loading door bolt replacement
« Reply #1 on: March 14, 2009, 03:03:23 PM »
Nice fix ...good job
jackel440
« Reply #2 on: March 14, 2009, 08:38:59 PM »
That's a nice job!I will make a note to use some sort of bushed door hinge on mine when i start building it.
New Holland LS170
24' Titan deckover gooseneck
96' Dodge Ram 2500 V10 4x4
Stihl 025
Stihl 038 Magnum
Stihl 041 AV
