Author Topic: Got owb going last night but fire goes out over night!  (Read 18806 times)
lasor1
  • OWF Brand: Heatmaster ss
  • OWF Model: Heatmaster mf 5000
« on: October 08, 2012, 06:21:36 AM »
Hello I got a heatmaster mf 5000 and I just fired it up yesterday for the first time and this is my first owb and I need a little help it heats the house great and hot water! I notice before I went to bed the fire looked like it was almost out but I stoked it and it started up good again Anyway I woke up this morning to a nice warm house and I notice air was a little cooler comming out of vents so I went to check stove and temp read 130 I the thermostat I have it set at 165 with a 12 degree swing  anyway I open fire box and no fire just some smoke rolling out of box it looked like it wanted to pickup again but couldn't so any suggestions on what I need to do to get this thing running smoothly. The temp was only in low 40s last night didn't know if it was taking to long between burntimes or what thanks!
Re: Got owb going last night but fire goes out over night!
« Reply #1 on: October 08, 2012, 07:04:28 AM »
Drop your differential from 12 down to about 5 until it get colder. That should help a lot.
lasor1
« Reply #2 on: October 08, 2012, 07:07:21 AM »
Thanks yoder I will give that a try.
johnybcold
  • OWF Model: Classic E1400
« Reply #3 on: October 08, 2012, 07:39:08 AM »
Welcome to the owf family, keeping it going it warmer weather can be a pain, these things wanna make heat if you house is not calling for heat the fire will not stay lite , please there is a fine art to loading it, it is something that takes a while to get the hang of, I call it owf voodoo
old truck
old craftsman chain saw
Polaris Sportsman 500HO
lasor1
« Reply #4 on: October 08, 2012, 01:26:01 PM »
I dropped differential swing down. And is working great so far!
johnybcold
« Reply #5 on: October 08, 2012, 02:39:31 PM »
What do you have your settings at? Mine died so I just set it to 30 second burst every 22 minutes
old truck
lasor1
« Reply #6 on: October 08, 2012, 03:13:18 PM »
165 8 degree swing
« Reply #7 on: October 08, 2012, 03:49:30 PM »
U won't have that trouble once you get a bed of coals developed..
johnybcold
« Reply #8 on: October 08, 2012, 06:28:19 PM »
Hopefully someone else will chime in but 165 might be low I think most of use have them set 180+ mine is at 187 seems to hit 189-190
old truck
« Reply #9 on: October 08, 2012, 06:39:52 PM »
Ahh, heatmasters new model shuts down at 190, I don't like that but oh well...    I've got a neighbor who runs is at 125 and 10 degree swing and has no trouble going out.  I know he's destroying his stove and all that but u can't fix stupid sometimes lol.
His problem is most likely not having a bed of coals established, however when burning wood I'd reccomend a 175-180 with a 10 degree diff, maybe less in warm weather
TM88
  • OWF Model: 5000E
« Reply #10 on: October 08, 2012, 06:58:13 PM »
Running mine at 180 with 15 differential.
scissorbill
« Reply #11 on: October 09, 2012, 06:06:19 PM »
A heatmaster going out at night??? That's weird.
lasor1
« Reply #12 on: October 09, 2012, 07:41:50 PM »
I haven't had any problems with it at 165 with diff at 8 do you recommend running it higher temp what are the pros and cons of running higher temps?
« Reply #13 on: October 09, 2012, 08:15:23 PM »
 I have run mine as low as 150 and as high as 180. Im burning green pine right now so I have my differential set at 3 because green pine is a major pain to burn during warm weather. I run the differential at 10 or 15 in normal burning during cold weather.
« Reply #14 on: October 09, 2012, 08:28:17 PM »
Go higher, def not lower..
I was ignorant to this for a long time.  If you run your stove at 150-160 and you pull off 20-30 degrees at times, your return water comes back to cold and it really impacts the life of the boiler, because, moisture from burning wood will gather on steel cooler than 140.  If u have a spot on your stove where the return water is cooling the steel down to below 140, moisture will develop there, and run down into the ashes
I don't reccomend to anyone to run less than 175
