Author Topic: lil boiler  (Read 8060 times)
bigdaddyjak
  • OWF Brand: Homemade
lil boiler
« on: October 09, 2012, 03:36:26 PM »
not a huge thing by any means, but i can say, i have owned an aquatherm. i believe it was a 275, it was rated for 5000sqf. so this should have enough water to heat 2500sqf
peacmar
Re: lil boiler
« Reply #1 on: October 09, 2012, 06:47:59 PM »
Can't make out the pictures too well..... Is that a 55 gallon drum? Might I add that water volume is not a definition of heating capacity nor is square footage. I heated my 3500 square foot  shop last winter with a small gasifier that only held 30 gallons, but required approximately 84,000 btu/hr to maintain 65 degrees with a temperature differential of 50 degrees. Not all that healthy but 16' ceilings take their toll....
My point is that the water is as much of a heat transfer medium as it is storage. If you circulate water continuously and have a healthy enough fire you could heat a very very large area with that. Your only set back potentially is surface area to transfer heat to the water. Maybe I'm looking at this wrong as I cannot make out very well from the pics, but if I am seeing what I think I am, it could work very well as long as every other factor not related to the burner is ideal to the conditions of operation.
bigdaddyjak
Re: lil boiler
« Reply #2 on: October 10, 2012, 01:45:03 PM »
Sorry, not sure why the pic ended up so small, yes it's a 55 gallon drum
Re: lil boiler
« Reply #3 on: October 10, 2012, 03:05:45 PM »
What happened to the Aqua-Therm?
bigdaddyjak
Re: lil boiler
« Reply #4 on: October 11, 2012, 10:07:00 AM »
Sold the house
bigdaddyjak
Re: lil boiler
« Reply #5 on: October 11, 2012, 10:09:01 AM »
I have messed with the aquatherm enough, when i decide to build a permenent one i will build it same as aquatherm
