Author Topic: Hx  (Read 5910 times)
Kpatton
  • OWF Brand: Natures comfort
  • OWF Model: nc250
Hx
« on: October 14, 2012, 07:18:54 AM »
Have no boiler inside do I need Hx or can I tie owb right right
To baseboard with zone valve and bypass loop for when heat
Is not needed.
BoilerHouse
  • OWF Brand: Home Built
Re: Hx
« Reply #1 on: October 14, 2012, 02:15:31 PM »
No need for a HX unless you also have a forced air system of some sort with existing duct work.  You should be fine with baseboards and zone/bypass valve(s).
Muskoka, Ont
Kpatton
  • OWF Model: nc250
Re: Hx
« Reply #2 on: October 14, 2012, 07:50:58 PM »
It will be open to air not presureized system. That is ok.
Should I have pump on owb wired to run 24/7 or to come
on when heat is needed.
BoilerHouse
Re: Hx
« Reply #3 on: October 15, 2012, 04:05:54 AM »
Most systems on this forum are non pressurized and open to atmosphere and most members  (including me) seem to run their pump 24/7, and shut it off during the non heating system.
Muskoka, Ont
Kpatton
  • OWF Model: nc250
Re: Hx
« Reply #4 on: October 15, 2012, 04:48:26 AM »
Ok thanks for info. Let pump run 24/7 & use zone valve to stop from heating baseboard when house up to temp. should do bypass  at valve to send water back to owb when house at temp.
