Author Topic: I started my mf 3000 and started mixing coal with wood can't believe the burn  (Read 5650 times)
Longleg
  • OWF Brand: Heat master
  • OWF Model: Mf 3000
Fired up my MF 3000 last weekend this is my second season still kind of learning the ropes. Bought a ton of coal to mix with wood really makes for longer burn time anyone else. Using. Coal The hot showers are worth it
94supercam
I burn straight coal. Would never go back to wood.
Longleg
How much coal do you use & what type of coal do you use the coal iam using is about the size of a golf ball but has a lot of dust mixed in I paid $ 250 a ton I throw a few Rounds of wood in and 2 small flat shovel of coal burns really good thick gray smoke when on first burn normal after that. I live in thaxton Virginia
94supercam
I burned quite  a bit last year. like 15 ton. but i was loosing allot of heat in the ground. redid  my lines hoping for allot less this year.  i work in the mines an get it. its met coal for steel, cleaned an no dust. its like pea coal. Mine smokes very little only when you first fire it.
