Author Topic: What / How if No electricity  (Read 10042 times)
netwerx-r-us
  • OWF Model: Hoss 400HE
    • Netwerx-R-Us
« on: October 28, 2012, 05:29:54 AM »
Morning all , In light of the weather coming and a question I have had a while while considering my design  , what is the recommended method of redundancy to keep these running when the electricity goes out? it seems to me that this is the single point of failure , no electricity no heat ?? as I am doing this not only for my house heat but a greenhouse that has tropical plants and cage birds that cannot freeze. At a bare minimum I see the need to have the circuit for the OWB  for the pumps and the furnace fan  for heat to keep somehow running , how and what are some of you doing to  address this . I remember the ice storm of 93 in this area and we had no electricity for a week
thanks all in advance , awesome site and people
Netwerx-R-Us
http://netwerx-r-us.com
Echo 440
Honda Rancher 400
Kubota ZD326
Re: What / How if No electricity
« Reply #1 on: October 28, 2012, 05:33:18 AM »
I have a generator that I fire up when the house power goes out. It is a 6000 W and runs everything fine.
« Reply #2 on: October 28, 2012, 05:46:01 AM »
Years ago when my dad was still alive, his health was failing so it was decided to install a whole house emergency generator using propane.  We have a 250 pound propane tank for cooking, drier, etc... that fuels it.  It will automatically come on 45 seconds after a power failure.  Believe me, it's a God send.  When you have an elderly parent living at home and you have to be at work all day, it's a peace of mind knowing that the house will be warm for him in the event of power failure.  It has never let me down.  Every year I perform maintenance on it to be sure it's operating properly.  My dad lost his battle with emphysema a bit over 6 and 1/2 years ago but the generator continues to do it's job by keeping the blowers, pumps, etc... operating in the OWB.  It was pricey but for me worth every penny.  Roger
boilerman
« Reply #3 on: October 28, 2012, 06:01:59 AM »
I agree. A 6000 watt generator is a great piece of mind. It should be enough to keep all your heating componants working and then some. Should be able to get a good one for easily under $800. I have a switchbox wired into my main power box. Just throw the bypass lever on the box, plug in the generator, fire it up and life is good. Won't supply everything in the house, but I alternate flipping breakers on freezers, refridgerators, etc. With pumps going, OWF and exchanger on my water heater, I even have all the hot water we need.
johnybcold
  • OWF Model: Classic E1400
« Reply #4 on: October 28, 2012, 06:11:48 AM »
Yup when I got my owf my wife said then ya gotta get a generator so I got a 7k
old truck
old craftsman chain saw
Polaris Sportsman 500HO
« Reply #5 on: October 28, 2012, 05:22:14 PM »
Basically you need a generator....You dont need a high watt generator to run a owb..Its only 110 amp.. Depending on what you wanna run (110 and 220 amp.), That will determine what size generator you need..Then theres a question get the loud box ones or spend the extra for the super quiet ones, where if u camp u can take it with you and have no complaints..
muffin
« Reply #6 on: October 29, 2012, 07:13:15 AM »
I think you mean 110V and 220V.  The furnace is likely 110V, but if you run a central unit for fans, they are going to be 220V.  A 220V unit would probably be easier to install as you can simply feed it right into your breaker panel and then run what ever you can support.
AirForcePOL
  • OWF Model: G400
« Reply #7 on: October 29, 2012, 10:20:57 AM »
Agreed.  If you are going to get a generator I would recommend installing a transfer switch in you main electrical disconnect.  If you buy a generator with a 220V output you can just plug it right into your panel and run anything that is fed off of that, whether it be 110 or 220V.
It would be a lot easier than running a power cord to each individual item that needed to be ran.  I have been wanting a generator for a while but just can't afford it.
Athens, Illinois
Dealer for HeatMaster SS
Stihl MS 290
Troy Bilt 27 ton splitter
netwerx-r-us
    • Netwerx-R-Us
« Reply #8 on: October 29, 2012, 11:51:39 AM »
good food for  thought , definitely need to look at investing in a generator just in case , thank all of your for your replies
anyone doing anything with batteries and pumps ?
Netwerx-R-Us
Echo 440
Honda Rancher 400
Kubota ZD326
MrDan27611
  • OWF Model: ML42
« Reply #9 on: October 30, 2012, 09:15:30 AM »
I just listened to Steven Harris' two podcasts on generators on the survival podcast. Having done pretty much everything he talks about, both the good and the bad, I thought it was a good overview. He also references another podcast he did on battery and inverter backups. I don't recall what number that one was but it's available on his site. You can access 1 of 2 of the generator podcast at:
http://www.thesurvivalpodcast.com/harris-on-generators-part-1-of-2
And obviously 2 of 2 follows right behind.
Don't go around saying the world owes you a living. The world owes you nothing. It was here first.
Mark Twain
