Author Topic: adding backup boiler & heat exchanger ???  (Read 6286 times)
svtnut
  • OWF Brand: acme
  • OWF Model: 320
« on: October 29, 2012, 05:14:33 PM »
Hello to all, I'm new to this site. Could use some advise here. First of all I have an old steam system that i have converted. Not your conventional hot water system, but it works. I have blocked off the ends of the main header trunk line so the water has to go thru the radiators, into the return (condensate) side of the old steam system. Anyways I have attached  two copies of the way my system is now and how I think I need to add this back-up boiler and heat exchanger. My understanding is with this model 7500 thermostat, I can control two heat relays. My plans are to set the gas boiler temp control a couple of degrees less of the main pump so if outside boiler dies down the main pump is still running and the LP gas boiler will kick on.  One concern  I have is if I have the tee in the best location between the heat exchanger and gas boiler. The manifold above the boiler is a 4" SS pipe with 1" ports that I made before I decided to buy a heat exchanger and make it a close system.
 Does this look like it will work ?
« Last Edit: October 29, 2012, 05:52:51 PM by svtnut »
abarton
  • OWF Brand: taylor
  • OWF Model: 450
Re: adding backup boiler & heat exchanger ???
« Reply #1 on: October 29, 2012, 08:06:45 PM »
threw this drawing together
"I could have saved a fortune when I built my house if only I had not installed any light switches but instead straight wired all the lights. I'm the only one that realizes they also turn off"
