Pages: 1 [2]
Author Topic: furnace install near woods  (Read 19802 times)
MattyNH
  • OWF Model: 7300E ; S-275
Re: furnace install near woods
« Reply #15 on: November 03, 2012, 07:10:33 PM »
My boiler is surrounded by trees, woods...Never a problem..Go for it!
Crown Royal 7300E (2021)
Aqua-Therm S-275 (2006)
Jonsered 2188
Jonsered 2165
Jonsered 2050
Kubota L3800DT
kc
  • OWF Brand: Earth
  • OWF Model: Mountain Man 505
« Reply #16 on: November 03, 2012, 08:43:54 PM »
I got it formed up today and I will end up about 10' - 15' from the edge of the woods.   I trimmed back a bunch of the small stuff and there are a couple of other mid-sized trees I will probably trim too.   Tomorrow is pad day.   Back of the truck is loaded with concrete.   Still need to dig out a pex hole and gravel fill but I should be mixing and pouring by late morning.   One small step but it feels good to actually start work on something given so much thought.
Thanks again for the feedback!!!
kc
Earth Mountain Man 505
Stihl MS361 - 25"
Stihl MS280 - 20"
Stihl 028 Wood Boss - 18"
Sthil MS170 - 16"
Echo CS-305 - 14"
Bull
  • OWF Model: Rebuilt H2
« Reply #17 on: November 04, 2012, 04:35:46 PM »
Congrats kc, you will love it
Southern Indiana
« Reply #18 on: November 04, 2012, 04:38:39 PM »
mixing concrete....stove is not hooked up but allready it is keeping you warm :thumbup:   ;D
kc
  • OWF Brand: Earth
« Reply #19 on: November 04, 2012, 05:12:48 PM »
Got her poured today so the first big step is done.    Now to figure out my pex and HEs and get the stove on the pad.   I am hopeful to get it fired up before old man winter get serious.   Doing much of this myself is pretty satisfying and it's great to get advice on a site like this.   I sure appreciate it...
kc
Stihl MS361 - 25"
Stihl MS280 - 20"
Sthil MS170 - 16"
Echo CS-305 - 14"
moparevers
  • OWF Brand: Earth
  • OWF Model: Rancher 365
« Reply #20 on: November 07, 2012, 09:04:22 AM »
I'm in the market, and leaning toward the Earth 365 too... so please let us know what stove you put on your new pad!
kc
  • OWF Brand: Earth
« Reply #21 on: November 08, 2012, 06:43:42 PM »
I am torn between the 365 and 505.   Pretty much the same but the 505 has another foot of firebox and 80 gallons more in the water jacket.   I think the 365 would work but the extra capacity of the 505 may be nice too as I am considering up to 6 different heating applications...
Stihl MS361 - 25"
Stihl MS280 - 20"
Sthil MS170 - 16"
Echo CS-305 - 14"
dwneast77
    • HeatherWood Gardens
« Reply #22 on: November 08, 2012, 08:08:27 PM »
I'm of the mind to buy heavy and use light vs buy light and use heavy.  The 365 may be sufficient for you.  I don't know the extent of your potential heat load but 75k extra BTU's and a little extra water can only be a good thing.  And a bigger firebox should extend burn time a little.
Eastern Maine (near Calais)
Central Boiler E-2300
Wood Doctor HE10000
Stihl 290 Farmboss
Craftsman 27 ton Splitter
JD 870 Tractor
walkerdogman85
  • OWF Model: H-4
« Reply #23 on: November 09, 2012, 05:52:55 AM »
I heat 1600 square feet and could have bought the h-2 but I bought the h-4 instead with this cooler weather I am easily getting 24 hours plus burn
Michael West
Central Ohio
sw18x
  • OWF Brand: Mahoning
« Reply #24 on: November 09, 2012, 09:45:51 PM »
Crazy to hear you guys say your furnaces don't throw sparks... Just tonight I took the dog out for a leak and stood on the back porch admiring the stack on my Mahoning, cherry red and snorting flames like a dragon. Seriously, my unit isn't fancy but it puts out some heat. This is my second full season running it, and there are times it still scares me. With a full load of wood and recovering from the low end of a cycle, the stack gets so hot you can almost see through it. I used to stand out there watching to make sure the sparks didn't ignite anything, but now I find it easier to just turn a blind eye and walk away.
No woods nearby, by the way, just a pasture and barnyard...unless you include my wood, and the metal polebarn 8 feet away...
dwneast77
« Reply #25 on: November 11, 2012, 08:57:00 PM »
Wow sw18x!!   Kind of sounds like a lot of wasted heat.  I've seen that on occasion with my CB 2300 gasser, but only when I had the bypass damper open to top it off with wood and there was a roaring blaze going in there and the flames are going right up through the bypass damper.  But when I close the door and bypass damper it stops imediately.  Most gasser models are set up with the hottest flame occurring at the bottom of the stove and and heat exchangers to extract the heat while  the exhaust makes it's way up and out the chimney.  Commom stack temps range from 250 to 400 on average.  Portage and Main pushes the fact that you can put your hand inside the final exhaust point or over the stack without getting burned as they have the most elaborate heat exchanger system that I've seen never allowing the exhaust temp to be over around 300 degrees.
Don't get me wrong.  Sounds like it would be impressive to see your stove.  At least you know when you have a hot fire going.  If only you could harness the heat that is getting wasted.  Burning that hot, I bet you don't see very much smoke  out of if as I imagine it's burning the gases coming out of the wood.
Wood Doctor HE10000
Stihl 290 Farmboss
JD 870 Tractor
Pages: 1 [2]
