Author Topic: 5036 door latch bolt broke  (Read 5123 times)
pwdiver
  • OWF Model: CL5036
    • narronseggstra's
« on: November 15, 2012, 03:30:54 AM »
Ive been on the central boiler web site trying to find the 3/8 door latch bolt that hold's the latch handle, I broke mine yesterday while cleaning the boiler out. Does anyone know where I can find a new one or a part number. Ill probably have to call central boiler. Thanks for any info  :-[
New Holland TC30 tractor
powerdiver6000@aol.com
snakedriver
  • Guest
Re: 5036 door latch bolt broke
« Reply #1 on: November 15, 2012, 06:49:51 PM »
Hello PW,
Call me a rebel, but I would not at all be concerned over OEM hardware. I would procure and install a galvanized (not zinc coated) hex bolt with a flat washer under the head so as to give a greater surface area against the handle. Personally, I would get a long enough bolt to put a nut on the far side of the tapped hole through the door to act as a stop nut. Ideally a split lock washer would go between the nut and door but the taper in the cast door negates that.
Best wishes!
J
pwdiver
  • OWF Model: CL5036
    • narronseggstra's
« Reply #2 on: November 17, 2012, 05:36:47 AM »
Thanks for the info I took bolt to work and a machinist fixed it. I didn't know that they where called shoulder bolts
