Author Topic: Water nitrite problems??  (Read 15478 times)
jon d
« on: May 30, 2009, 07:30:07 PM »
Testing water per the central boiler test kit.. Ph 8.0 nitrite at 38. Drained 10 gals and refilled. Nitrite was 32 and ph was 6.. Book says it needs to be ph of 8.5 and nitrite level of 15-20. Main problem now is low ph with higher than normal nitrite. Any ideals........????? ???
jon d
Hawesville, Kentucky
Central boiler 5036 installed in 09
jon d
Re: Water nitrite problems??
« Reply #1 on: May 31, 2009, 07:27:53 PM »
Update!! After another 24 hrs. with pumps running,, water is testing at a ph of 7 and nitrite of 24.  Nitrate is still high and ph needs to be 8-9.5.????? calling dealer....will update later
jon d
jon d
« Reply #2 on: June 08, 2009, 08:48:49 PM »
ordered new test kits! Last test was 7ph 24 nitrite.  any help???
jon d
Alan
« Reply #3 on: June 23, 2009, 08:13:36 PM »
did you fine the problems
Alan  Marydale ky
jon d
« Reply #4 on: July 01, 2009, 09:13:34 AM »
New CB test kits came in.. ph was 8 and nitrite was @18. All is well now..
jon d
R W Ohio
« Reply #5 on: July 04, 2009, 05:13:38 AM »
jon,
How many tests can you make from one test kit and how much do they cost?
R W Ohio
Canal Fulton,Oh.
jon d
« Reply #6 on: July 04, 2009, 03:05:09 PM »
Test kit cost @20. If water is within the correct ph and nitrite range, I would guess you could probably run about 20 test. If your nitrite test results are high, you will use alot of chemical to obtain your test results.
jon d
