Author Topic: Water heater  (Read 16142 times)
kevinjem
Water heater
« on: April 09, 2008, 07:14:56 PM »
Hank are you using a side arm to heat your water. Or are you running water straght from yor boiler can really tell the the pictures.
PhinPhan
  • OWF Brand: WoodMaster
  • OWF Model: 4400
    • Outdoor Wood Furnace Info
Re: Water heater
« Reply #1 on: April 10, 2008, 10:46:55 AM »
Most hardy's the hot water is heated inside the boiler itself.  If you look at the picture in this link (below) you can see the domestic hot water coil the water heats up while it runs through this coil then back into your hotwater tank.
http://www.hardyheater.com/Products/Specifications/specifications.html
Pomeroy, OH
WoodMaster 4400
