Author Topic: Water change in a 5036  (Read 4135 times)
pwdiver
  • OWF Model: CL5036
    • narronseggstra's
« on: November 17, 2012, 07:18:48 AM »
Ive seen several post about not doing a full water flush/change at 3 year's if the water is still clear and not showing any noticable rust from the drain. I checked this morning with my kit which I got last april, Ph showing about a 9 did the nitrite test it took 31 drop's. The water I got at the drain on bottom of boiler after  rising the jar was pretty clear had a couple of rust partical's and some white speack's floating in the water. This boiler has been going none stop since march of 2009. :-\
New Holland TC30 tractor
powerdiver6000@aol.com
pwdiver
  • OWF Model: CL5036
    • narronseggstra's
Re: Water change in a 5036
« Reply #1 on: November 20, 2012, 07:32:44 PM »
Well just to let every one know I did not drain my system, I figure if I get info at a latter date Ill change the water in boiler then
woodywoodchucker
  • OWF Brand: cental boiler
  • OWF Model: classic 5036
« Reply #2 on: November 20, 2012, 07:45:26 PM »
I was told by my dealed its not recommeded
