Author Topic: Temp programming...How to?  (Read 7661 times)
Tree_Killer
  • OWF Model: MF5000SS
« on: November 18, 2012, 04:54:38 PM »
Ok, since I didn't receive a manual from previous owner...how do you program a heatmaster?  I seen a lot of you all are saying 165-180 temp with a 15 degree swing. But since I don't have my manual A: I am not completely sure what that means? B: Not sure how to adjust/program it?  C: is this something I have to do yearly if power is shut off completely to furnace?
Anything else I should know?
I am trying to get a copy of a owner manual...hopefully heatmaster will come through for me on that.
Climb High Tree Service
Lebanon PA
Certified Arborist
"Kiss My Axe"
Tree_Killer
Re: Temp programming...How to?
« Reply #1 on: November 18, 2012, 07:10:02 PM »
Another question on burning.  The wood in the back of the fire box seems to disappear fast. But the wood in the front (by door) doesn't seem to want to completely burn. Normal?
Lebanon PA
Certified Arborist
"Kiss My Axe"
Tree_Killer
« Reply #2 on: November 18, 2012, 07:15:25 PM »
thermostat/control panel
second pic of tank water circulator temp control (i guess)
« Last Edit: November 18, 2012, 07:42:22 PM by Tree_Killer »
Lebanon PA
Certified Arborist
"Kiss My Axe"
mcarter
  • OWF Brand: HeatMasterSS
  • OWF Model: MF5000e
« Reply #3 on: November 19, 2012, 04:48:31 PM »
Tree_Killer,
Follow this link for the PDF instructions for your controller:
http://www.etcsupply.com/manuals/ranco_etc_instructions.pdf?osCsid=2e6bbd128c5369beab15f34dbd15915d
Under 'Programming Steps and Display', you will see the steps to follow for setting the differential.
Happy burnings!
Michael
MS 460 Stihl Magnum
Husqvarna 345
5 acres
MO_Hunter
  • OWF Brand: Heatmaster SS
  • OWF Model: CS-4000
« Reply #4 on: November 23, 2012, 08:13:54 AM »
Push set button pick C of F with up or down arrow buttons
Push set button  set upper temp ( 165 - 185 ) with arrow buttons
Push set button set lower temp ( 15 deg diff ) with arrow buttons
Push set.
Done
So if you are wanting to run a 15 deg cool down for 165 deg upper temp set you lower temp to 150.  Once the furnace hits 149 the blower will kick on until the temp reaches 165.
Wood at back will burn faster the front if your blower is mounted on the front door, like mine is, but all will burn.  When I reload I push everything back and load new.  I have a long metal hoe that I use to even ashes and push wood to back.
