Author Topic: pex expansion  (Read 7567 times)
MD20/20
  • OWF Brand: Nature's Comfort
  • OWF Model: 325G
pex expansion
« on: November 21, 2012, 05:33:42 PM »
How do you guys deal with expansion of pex in your basements?  I have over 2ft of expansion over approx 30 ft. of pex line in my basement going to heat exchanger.  The total line in 260ft.  My original set up leaked on start up this year and I made some modifications and they seem to be working.
Central MD
BoilerHouse
  • OWF Brand: Home Built
Re: pex expansion
« Reply #1 on: November 21, 2012, 07:04:40 PM »
My line from OWB to house is 160 ft.  Inside the house it runs another 15 or 20 ft and there are a couple of lazy 90 deg bends that allow for expansion and contraction.
Muskoka, Ont
Re: pex expansion
« Reply #2 on: November 22, 2012, 06:57:53 PM »
 If I don't want it to move I fasten it down before we fire the furnace up.
MD20/20
  • OWF Model: 325G
Re: pex expansion
« Reply #3 on: November 22, 2012, 07:24:38 PM »
Where does the expansion occur if you fasten it down? In the buried section of the PEX?
Central MD
Re: pex expansion
« Reply #4 on: November 22, 2012, 07:31:07 PM »
I assume so, I just know if I attach it securely in the basement it doesn't expand into there.
Red_Nek
  • OWF Brand: Carolina Water Stove
  • OWF Model: CWS-500
Re: pex expansion
« Reply #5 on: November 22, 2012, 11:26:17 PM »
When I installed my furnace, I had prior knowledge of the pex expansion issue. With this in mind, I decided to leave a service loop on the wall so that it could expand there. This way the expansion didn't torque a fitting or bind up in an area that couldn't handle it.
Dave
Famous Quotes from Hillbilly Philosophers:
1) Experience is something you don't get until just after you need it.
2)The journey of a thousand miles begins with a broken fan belt and leaky tire.
3)The quickest way to double your money is to
fold it in half and put it back in your pocket.
