Pages: [1] 2 3 4
Author Topic: HARDY EFFICIENCY PLATES  (Read 70534 times)
ford tech
  • OWF Brand: hardy
  • OWF Model: h2 2003 - 2014 CB 6048
« on: November 24, 2012, 07:24:43 AM »
I FOUND THIS ON YOU TUBE - HARDY EFFICIENCY PLATES - SOUNDS LIKE A GOOD IDEA . DOES ANY ONE HAVE THIS AUGER IN THERE H2
stihl ms460
stihl 36pro
farmall h
HARDY H2 heating 1600sqft home and 42x42 insulated MORTON shop floor heat - installing a cb 6048
AirForcePOL
  • OWF Model: G400
Re: HARDY EFFICIENCY PLATES
« Reply #1 on: November 24, 2012, 09:03:27 AM »
That's interesting.  I have never seen those before.  I would think that there would be a lot of build up on them after a while.
Athens, Illinois
Dealer for HeatMaster SS
Stihl MS 290
Troy Bilt 27 ton splitter
walkerdogman85
  • OWF Model: H-4
« Reply #2 on: November 24, 2012, 07:29:28 PM »
Tried to find the video but said there we no results can you post the link so I can go to it from here
Michael West
Central Ohio
slosh250
« Reply #3 on: November 29, 2012, 08:03:46 PM »
Seems like a good idea, I heard on another site they were 60 bucks plus shipping. 330-485-6310 they said to leave a message and he would get back to you. May get one for my h2 and see what happens.
AirForcePOL
  • OWF Model: G400
« Reply #4 on: November 30, 2012, 07:07:24 AM »
Hey Slosh let us know how it works out if you end up buying one.  If they are only $60 it would probably be worth it just to try it out.
Athens, Illinois
Stihl MS 290
slosh250
« Reply #5 on: December 01, 2012, 06:00:03 AM »
you bet it wouldthe bad thing is i dont keep a close eye on wood consumption so how would i know any different lol maybe ill start. seems like it would creosote up if you burn green wood.?.?
dumbodog00
« Reply #6 on: December 01, 2012, 07:28:57 PM »
That is the dealer that I bought my H2 from.  He knows the stoves very well.  He has worked with Hardy for quite a while in developing and tweaking their products.
AirForcePOL
  • OWF Model: G400
« Reply #7 on: December 02, 2012, 06:54:03 PM »
I was thinking the same thing slosh.  I guess it wouldn't be hard to take it out and clean it though.
Athens, Illinois
Stihl MS 290
Brauma
  • OWF Model: H2
« Reply #8 on: December 27, 2012, 06:57:05 PM »
I called and left a msg today too. For $60, I'll give it a try.
I've been very disappointed in the wood consumption of my H2. I've tried various things, such as made an adjustable chain on my fan door so I could control the air intake, and adjusted my water temp lower. But wood consumption didn't change by any noticeable degree.
I like his idea of the corkscrew in the stack. Makes sense.
slosh250
« Reply #9 on: December 31, 2012, 09:18:40 PM »
Am going to get one myself. have lost the contact number and i need a new stack also, mine is all beat the crap from the previous owner "cleaning creosote". Anyone know how much a new stack is?
Farmer Blue
  • OWF Model: H-4
« Reply #10 on: January 01, 2013, 06:44:52 PM »
 I have an H-4.  I have had the plates for over two years. The amount of wood used dropped 25-33%. Green wood or pine can be a problem with build up. There is slide in the middle to let deposit/ash that builds in the stack drop out. I burn newspaper or card board about once a week to heat up and burn out any build up of creosote. If I let it go to long it will build up and the draft will go to nearly zero. Then I have had to let the fire go out and work a screwdriver around the edges to clean it out. I also am able to take a stick and lift and shake the plate to keep a build up from forming. The number you listed as the contact is my local dealer that came up with he idea.
Hardy H4
Stihl 290
Homemade splitter on IH 656
AirForcePOL
  • OWF Model: G400
« Reply #11 on: January 02, 2013, 08:35:17 AM »
Slosh, When I bought a new stack for my H-2 it was $45 from the dealer.  I think I'm going to order one of these augers for my H-2.
Brauma - Did you get your auger yet?  If you have, let us know what your opinion is.
Athens, Illinois
Stihl MS 290
Brauma
  • OWF Model: H2
« Reply #12 on: January 02, 2013, 11:11:58 AM »
I called and left a msg on the 27th. Still no return call yet. Quite disappointing.
slosh250
« Reply #13 on: January 11, 2013, 09:26:44 PM »
I talked to him today, price went up to 75 bucks plus shipping a 15lb box ups. Thinking of just making my own. Just need to find a 6" auger
walkerdogman85
  • OWF Model: H-4
« Reply #14 on: January 12, 2013, 05:24:30 AM »
I would just make my own like you said if I can get some measurements for the h4 plate I am going to make it all it is is a piece of channel taking up more space int the top
Michael West
Central Ohio
Pages: [1] 2 3 4
