Author Topic: Saves my coals!  (Read 5263 times)
Intheoaks
Saves my coals!
« on: December 09, 2012, 08:43:03 AM »
 Was wondering if anyone else does this, maybe some other boilers have it built-in? I hooked up an aqua stat on my return line at the OWB to shut off the draft fan when the water temp falls. This has saved me on many an occasion from having to refire my boiler from scratch. If for whatever reason I do not have enough wood burning to sustain the setpoint temperature the aqua stat shuts down the fan and the coals smolder for long periods of time, when I throw more wood on then I throw a bypass switch and the fan fires up and the wood catches without the hassle of restarting a fire. There is also an added benefit because when the wood is running out the fan forces cold air through the boiler and cools the boiler water faster than it would without the fan.
 This has worked well for me for 8 years, just have to remember to flip the bypass switch after the temp comes back up, this can be the hard part!
Re: Saves my coals!
« Reply #1 on: December 09, 2012, 08:50:44 AM »
What if you use a timer switch for the bypass?
I have been thinking about doing it but never got around to it.
dwneast77
    • HeatherWood Gardens
Re: Saves my coals!
« Reply #2 on: December 09, 2012, 09:36:27 AM »
An excellent idea!!  Someday maybe I'll do that.
Eastern Maine (near Calais)
Central Boiler E-2300
Wood Doctor HE10000
Stihl 290 Farmboss
Craftsman 27 ton Splitter
JD 870 Tractor
yotehunter66
  • OWF Brand: Woodmaster
  • OWF Model: 4400
Re: Saves my coals!
« Reply #3 on: December 11, 2012, 06:39:08 PM »
My Woodmaster has it built in to the programmer.
« Last Edit: December 11, 2012, 06:41:14 PM by Yotehunter66 »
Husky 372xp 24"
Makita DCS520i 20"
Poulan 2300 18"
Troybilt 27 ton log splitter
