Author Topic: new to outdoor wood boiler need help with install of 10 plate for dhw  (Read 7344 times)
mdsman
I am new to OWB i just purchasd a used unit and have most everything fgured out except how to plumb into my propane hot water heater. I have searched and there is no direct info as to where to hook it up on hot water heater. I thought you hook it up on the bottom of the tank and then the top where the cold supply is but I am unsure please help!!
Re: new to outdoor wood boiler need help with install of 10 plate for dhw
« Reply #1 on: December 09, 2012, 09:21:11 AM »
bajonesy77
  • OWF Brand: Prosteel
  • OWF Model: 200
« Reply #2 on: December 10, 2012, 11:09:02 PM »
That's how mine is done but with 20 plate. Never run out of hot water and water heater is turned off at the breaker.
Brave 22 ton splitter
Stihl 440 magnum 20" bar
Stihl 390 20" bar
oldchenowth
« Reply #3 on: December 11, 2012, 06:40:25 AM »
What he said :post: I got a sweet deal on a 30 plate. Freakin awesome man!!!!
sumptersmoker
  • OWF Brand: Centeral Boiler
« Reply #4 on: December 12, 2012, 05:30:56 AM »
Do you have a mixing valve on your unit ?
oldchenowth
« Reply #5 on: December 18, 2012, 05:23:34 AM »
Not sure about Jonesy, but I do not have a mixing valve.  I know I will get flack for that from the guys here.  I have mine set up after the furnace HX and use the tank as storage.  We still can get water above 125 F, so it is imperative we are concious of the temp for shower and sinks.
