Author Topic: Thermostatically-controlled three-way valve  (Read 4795 times)
snakedriver
« on: December 30, 2012, 07:30:16 PM »
While visiting a friend who has an OWF, he complained to me about having to open a window because it got too hot on the house. Having an OWF myself, and thinking I knew a thing or two, I figured that I could make a suggestion for him.
After hearing his explanation (not needing the blower in the relative warmer times of burning), it became obvious to me that merely the circulation of the water from the OWF pump through the crawl space and air/water heat exchanger in his ductwork radiated heat into the home. While this is to me a substandard installation,  allowing too much heat to escape by not being insulated properly (and causing more wood than necessary to be burned), he is a sensitive sort and would not respond well to the suggestion that it wasn't installed properly.
It is my idea to suggest to him a three-way valve to be installed at the pex entry point at the crawl space. This valve would be operated from a signal from the thermostat inside the house which operates the blower. When the thermostat is happy an the blower is not running, have it signal this three-way valve to bypass the house loop and return the flow back to the OWF.
My questions are: 1. What is the proper valve for this? and 2. Any other suggestions? I don't wish to suggest interrupting power to the pump. For several reasons.
dwneast77
    • HeatherWood Gardens
Re: Thermostatically-controlled three-way valve
« Reply #1 on: December 30, 2012, 10:32:30 PM »
That is exactly the best way to do it if he's having trouble with the home overheating.  It was strongly suggested to me to do this setup and I'm happy I did.  I have 5 of these setups and it works great!!.  I'm my home i'm using a Taco 3-way zone valve wired to the thermostat and fan center relay.  Let me know if you want specifics on how to wire it.  Central boiler also has some diagrams on their site to help with it.  I assume he must already have the fan center relay??
[attachment deleted by admin]
Eastern Maine (near Calais)
Central Boiler E-2300
Wood Doctor HE10000
Stihl 290 Farmboss
Craftsman 27 ton Splitter
JD 870 Tractor
snakedriver
« Reply #2 on: December 31, 2012, 07:10:14 AM »
dwneast,
Perfect. I did look up the three-way zone valve on the Central Boiler site upon your suggestion. Since my own installation did not require such, I was unfamiliar. Your suggestion fits the bill exactly. Thank you! I have made the fix suggestion to my friend.
Kind regards from Georgia!
Jerry
