Author Topic: Shaver 290 have a couple of questions  (Read 7105 times)
Russ Brumit
« on: January 03, 2010, 11:39:38 AM »
I have a shaver 290,  Been running now for 5 months here in Elkton, Md. Works good but i need to do some mods. I heat a shop  (2700) square ft ) and house  (2300 ft) hot water in both. The hot water set up from shaver is perfect. The only problem i had in the sumer was the stove sometimes would go out because of not firing for days . Not that big of a deal . As for the winter , It works very well down to 20 degrees. I get burn times of 12-15 hours. I need to have at least 12 hours between filling due to my work schedule.  I've had the stove temp set at 130*  and moved it up to 145* in the last month .House is insulated well but shop isnt.(working on that)  Keep the garage set low,just above freezing unless i'm in there . i use two hanging heat exchangers running in series.
 Questions ,  Do you think i should raise the temp at the stove ?
                     I was thinking about replacing the thermostat and going with a digital or aquastat.  Any thoughts ?  Thanks Russ
   Heres my number if i can offer any help to anyone just give me a call  443-907-7455
Shaver  Series 290
443-907-7455
bruey
Re: Shaver 290 have a couple of questions
« Reply #1 on: January 03, 2010, 09:46:34 PM »
if you search this site there was someone talking about moisture buildup below a certain temp. i think your below it. i set mine at 170 upper limit and dont fill near all the way and get 12 hr. burns . it was 5 degrees this morning. i would try 160 first and see what happens, i think 150 was the temp you didnt want to go below, but to be safe you can search it on this site.
Newrichmond, Ohio
Russ Brumit
« Reply #2 on: January 04, 2010, 03:27:05 AM »
Thanks for the help.  I'll turn the temp up and see what happens.   What stove do you have ?
Shaver  Series 290
443-907-7455
bruey
« Reply #3 on: January 04, 2010, 07:33:59 PM »
pro-fab
Newrichmond, Ohio
