Author Topic: My first build  (Read 17059 times)
twoenker
My first build
« on: January 12, 2013, 02:22:21 PM »
Hey guys i m new to this forum and want to say that there is a lot of good info on here.  Im looking to start a build of my own outdoor wood boiler.  I have an old fuel oil tank that i was thinking about using in my build.  It measures 3'-6" tall and 2'-6" wide and 5 ft deep.  My question is do you think i should use this as the firebox or the water jacket?  Also is a round firebox better than a square one?  Any bit of info will be greatly appreciated and im excited to get this project rolling.  Thanks for your time
Re: My first build
« Reply #1 on: January 12, 2013, 02:52:35 PM »
Round is better, think about how many less welds there are vs a square box design.   The fuel oil tank seems to not be a good size for either, kinda an odd shape.  If you could find perhaps a 30" pipe and slide it into a 48" it would make things pretty simple
BoilerHouse
  • OWF Brand: Home Built
Re: My first build
« Reply #2 on: January 13, 2013, 07:47:56 AM »
I agree with Scott.  When I built mine I had thought of using a used fuel oil tank because they are so easy and cheap to get but I couldn't seem to work it into any practical design.  You could consider it for additional water storage however there is a whole other debate on the benefits of that.
Muskoka, Ont
twoenker
Re: My first build
« Reply #3 on: January 13, 2013, 10:11:02 AM »
ok thank you both for the info i am gonna try and see what kind of big pipe i can find im a pipefitter so im hoping i wont have a problem with finding pipe 30" to 40" in size lol.  Thanks again im gonna get back to the drawing board and see what i can find thank you so much for now im sure i will have more questions to come Thanks
Re: My first build
« Reply #4 on: January 13, 2013, 10:34:05 AM »
mine is 36 inside a 42 this time around the 36 is 5 feet long (fire box) and the water jacket is 7 feet long
Re: My first build
« Reply #5 on: January 13, 2013, 10:48:48 AM »
Thats a biggin Willie, how many gallons
Re: My first build
« Reply #6 on: January 13, 2013, 03:40:17 PM »
i think it is about 240 US gallons (about 200 Imperial Gallons)
happycamper
any body make a 275 gal oil tank wood stove
« Reply #7 on: March 15, 2013, 05:47:43 PM »
any body have or maked a 275 gal oil tank wood stove
tomsowb
  • OWF Brand: Homemade
Re: My first build
« Reply #8 on: October 27, 2013, 06:41:48 PM »
Hello All!
I am new to this sight and am planning to build my own boiler. I would like to use an old 275 gallon fuel oil tank, and a old  20" 80 gallon electric water heater for the fire box. These are materials that I already have in my inventory of scrap!
 I only need 60,000 btu to heat my home. I noticed that some said this may not be a good design, Why?
Thanks for any Input!
Rom
dave_dj1
Re: My first build
« Reply #9 on: October 28, 2013, 04:53:03 AM »
If I was to try and use a 275 gal oil tank I would make that the firebox and use the water heater as the vessel after all it's already a sealed unit and the oil tank is not.
I actually started one once this way and ended up scrapping the whole thing. If I was to do it again I would make the water tank slide in with some sort of gasket instead of trying to weld it in (it took forever!).
The only other thing I see is the thinness of the tank, it may burn through prematurely.
Good luck :thumbup:
beeman
  • OWF Brand: homemade
Re: My first build
« Reply #10 on: October 29, 2013, 09:00:37 PM »
old propane 500-1000 tank for the fire chamber 3/8 inch thick if it is made to small you will have to feed it all the time but i am not telling eny body to be crazy as i and cut on a propane tank
dukethebeagle
  • OWF Model: 0001 hot tamali
Re: My first build
« Reply #11 on: October 31, 2013, 07:12:35 PM »
hey dave dj1.i built mine with a 200 gallon oil tank and a 60 gallon used hot water tank.found a way to do this with about 5 to six hours in time spent building start to finish.you have to cut down on the number of joints you weld from cuts.building another one now for a neighbor and am half finished in maybe three hours.
austin qc
bluegrass rules
proud appalachian
dave_dj1
Re: My first build
« Reply #12 on: November 01, 2013, 06:36:02 AM »
Post up some pics! We like pics.  :pic:
vpd66
Re: My first build
« Reply #13 on: November 01, 2013, 08:23:43 AM »
I'd like to see pictures and more details.
dukethebeagle
Re: My first build
« Reply #14 on: November 01, 2013, 08:05:01 PM »
hey all.i was thinking about doing a vid and posting it on youtube.my first one using two tanks like this was long and not thought out.after completion i spent some time thinking about how to build it a little quicker and with less welds.i finally came up with a way for the 60 gallon in a 200 gallon oil tank.i will get that video soon and let you all know when it is posted.if you check wood boiler from junk on youtube it looks quite abit like it. to come soon.later
austin qc
bluegrass rules
proud appalachian
