Author Topic: 10000e question  (Read 17303 times)
birchbark
  • OWF Model: 10000e
10000e question
« on: January 22, 2013, 06:23:11 PM »
I just installed a new 10000e on thursday last week and since I've installed it, it has gone out on me a few times.  The fan is working fine and so is the solnoid.  When its gone out, there was still lots of wood in there and I am using very well seasoned dry larch.  So I am wondering if it could be getting choked out by the smoke during the idle time.  If so could it be from the length of chimney, would I need more of less.  All I put on it was a 3 foot extension piece.  Any idea's would be appreciated.
kybaseball
  • OWF Model: MF10000E
Re: 10000e question
« Reply #1 on: January 22, 2013, 06:43:57 PM »
What do you have your differences set at?
birchbark
  • OWF Model: 10000e
Re: 10000e question
« Reply #2 on: January 22, 2013, 06:46:25 PM »
I have it set at 175 to 180, but there has been a few times that I have gone out and had a look and seen it as high as 184, but of course the fan has shut off
kybaseball
Re: 10000e question
« Reply #3 on: January 22, 2013, 06:54:25 PM »
I have mine set at 180 with a 15 degree difference so the fan will kick back on at 165. Mine never goes over 182 after the fans shuts off at 180.
So you have yours set with only a 5 degree differnce?
kybaseball
Re: 10000e question
« Reply #4 on: January 22, 2013, 06:55:59 PM »
If you have time to talk call me at 502-523-8952 name is Michael
Re: 10000e question
« Reply #5 on: January 22, 2013, 07:15:59 PM »
It shouldn't be going out, it could be your not burning it long enough to get the coal bed hot...  Set it to a 12-15 degree differential and try that, smoke won't put it out, and the chimney length not affect it either.  The forced draft makes chimney length not very important, only go higher to help get smoke away from the area
birchbark
  • OWF Model: 10000e
Re: 10000e question
« Reply #6 on: January 22, 2013, 07:30:18 PM »
Hey Scott, I just got off the phone with Micheal, he said the same thing so I went out and changed the differential, I now have it set to 170.  Hopefully that takes care of it, cause like I said, everything else seems to be working the way it should.
thanks guys
kybaseball
Re: 10000e question
« Reply #7 on: January 22, 2013, 07:49:26 PM »
Scott I told him to set it at 180 with a 10 difference to help with burning longer.
Re: 10000e question
« Reply #8 on: January 22, 2013, 08:44:09 PM »
10-4!
kybaseball
Re: 10000e question
« Reply #9 on: January 24, 2013, 03:14:31 PM »
Just checking to see how the stove is doing?
birchbark
  • OWF Model: 10000e
Re: 10000e question
« Reply #10 on: January 27, 2013, 10:19:49 AM »
Seems to be working, but the water temp will drop down as low as 160 before it starts climbing again.
Re: 10000e question
« Reply #11 on: January 27, 2013, 10:49:35 AM »
I dont think it should drop that low unless your pulling heat off that quickly
what is the quality of your wood?
where is the draft set at?
kybaseball
Re: 10000e question
« Reply #12 on: January 27, 2013, 01:42:49 PM »
When I talked to him on the phone I told him To put the draft at 100%. Make sure that he using the shaker grate to get a good air flow to get the fire going.
Re: 10000e question
« Reply #13 on: January 27, 2013, 02:53:53 PM »
yup, as you know, when its gettin air and good wood, she comes to life!  :thumbup:
kybaseball
Re: 10000e question
« Reply #14 on: January 27, 2013, 04:56:57 PM »
I will have to agree with that!!!!! Thanks a lot Scott. Man i sure was worried.
