Author Topic: Steel Grade of Wood Boiler  (Read 7699 times)
Homerglide
  • OWF Brand: Orlan EKO
  • OWF Model: Out in the shop - Model 25 gasifier
« on: January 28, 2013, 10:58:29 AM »
Is there a definitive answer to what steel to use on firebox and water jacket?
My thoughts are that boiler or floor plate is not necessary. Hot or cold rolled A36 should be acceptable. Firebox should be 1/4" to still allow heat transfer while holding up to rough service. Water jacket at 10 gauge.
Will there be corrosion issues later with hot roll steel if it has not been acid cleaned (pickling)?
Are stays required in an unpressurized heater?
Coupla Chainsaws
Axe
Strong OLD Back
2000 Dodge Cummins
Re: Steel Grade of Wood Boiler
« Reply #1 on: January 28, 2013, 07:20:10 PM »
i built my stove out of pipe (what ever the metal compositon is) ((i think it may have been ASTM106))
i think 1/4 inch on the water jacket is good idea too (unless you are buying it new ;D ) this will give you some room for corrosion later in the stoves life?
BoilerHouse
  • OWF Brand: Home Built
« Reply #2 on: January 28, 2013, 08:13:57 PM »
I used 3/8 steel for the firebox and 1/8 for the water jacket - all mild steel.  After 4 years no problems to report.  Hopefully I will get 10 more years on it but only time will tell.
Muskoka, Ont
Bondo
  • OWF Brand: Home built
  • Master General Re-Engineer
« Reply #3 on: February 01, 2013, 03:22:18 PM »
Ayuh,....   Mines a propane tank, inside of an industrial water softener tank,...
both are 'bout 1/4" thick...
Don't think it's any sorta "Special" steel at all....
