Author Topic: Help Ranco temp reading E2 (Wont stay running)  (Read 6408 times)
Tree_Killer
  • OWF Model: MF5000SS
« on: January 30, 2013, 03:59:25 PM »
 We lost power today while I was out working. I am not sure when, or how the furnace was at the time.  A hour after I got home the power was restored. But the furnace wont stay on.  I reset breakers and temp settings...but nothing works.
The display reads e2. When I power it off and on (or reset temp settings) it clanks on and blows for about 30-60 secs that clanks off.
Water level seems ok, as in it didnt boil over.
Climb High Tree Service
Lebanon PA
Certified Arborist
"Kiss My Axe"
birchbark
  • OWF Model: 10000e
Re: Help Ranco temp reading E2 (Wont stay running)
« Reply #1 on: January 30, 2013, 05:39:46 PM »
This is what is says in my manual
E2 - Appears if the control settings are not properly stored
in memory.
To correct: Re-set all settings. If the display continues
to show E2, replace the control.
« Reply #2 on: January 30, 2013, 07:27:02 PM »
Normally when a Ranco starts reading e2 its time to replace it. Sometimes you can make it last a little longer by turning of power for a few minutes but they never recover completely. Its easy to change one, just pull the cover and rewire the same way you found it. I imagine you had some sort of power surge that damaged the Ranco. At least I have had several that were damaged by either power outages or lightning.
« Last Edit: January 30, 2013, 07:28:49 PM by yoderheating »
Tree_Killer
« Reply #3 on: January 30, 2013, 09:04:36 PM »
Ya i am pretty sure that is waht happen. I got it running for now. But going to get another one, and replace it.  Tomorrow I will open it up to gt model number etc.
Lebanon PA
Certified Arborist
"Kiss My Axe"
