Author Topic: Why CB factory sets at 175-185  (Read 10896 times)
victor6deep
  • OWF Brand: Burnrite
  • OWF Model: 228
« on: February 15, 2013, 05:02:00 PM »
Tech said this:
1. Firebox stays dry and clean including chimney.
2. Very little oxygen present in the water.
3. Eliminates bacteria growth in the water.
4. Overall most efficient.
Re: Why CB factory sets at 175-185
« Reply #1 on: February 15, 2013, 05:04:33 PM »
Yep....  And protects the company, that's the main one
dwneast77
    • HeatherWood Gardens
« Reply #2 on: February 15, 2013, 06:04:12 PM »
Mine came set at 175-180.  I was told to run it there for the first couple of weeks to help cure the steel or something.
Eastern Maine (near Calais)
Central Boiler E-2300
Wood Doctor HE10000
Stihl 290 Farmboss
Craftsman 27 ton Splitter
JD 870 Tractor
Jack72
  • OWF Model: E-1450 (11)
« Reply #3 on: February 16, 2013, 04:58:52 AM »
Mine is set at 180-190.      The hotter the better  my .02
Chevy 2500 HD 13 Duramax
Stihl 046 036 009
Northern Tool 25 ton Splitter
J Cooch
  • OWF Model: Cb5036
« Reply #4 on: February 16, 2013, 04:43:48 PM »
I agree 180-190. The forced hot water baseboards seem to work better for me above 180.
« Reply #5 on: February 16, 2013, 04:56:12 PM »
general figures for your hydronic baseboards listed for btu putput @180 degree water would be as this chart i found  says
120 degree water multiply listed btu output by 0.38
130  x.48
140 x .57
150 x .67
160 x .78
170 x .89
180 x 1.0
190 x 1.13
so yes for hydronic basebaords the hotter  the water delivered the more btu you put in the room per hour per foot of baseboard
« Last Edit: February 16, 2013, 05:20:34 PM by willieG »
victor6deep
  • OWF Model: 228
« Reply #6 on: February 16, 2013, 05:07:26 PM »
Do you guys ever have to add water here and there from evaporating water at such a high temp?
Jack72
« Reply #7 on: February 16, 2013, 06:28:19 PM »
Victor
I have not had to add water yet  it has dropped a tiny bit going on third year this year
Stihl 046 036 009
boilerman
« Reply #8 on: February 16, 2013, 08:28:31 PM »
I lose less than 1/4" of water per year to evaperation. The breather vent makes most condensation drip back into water jacket. I have found no need to add water in any of the CB furnaces I have ran.
« Reply #9 on: February 16, 2013, 09:33:17 PM »
Adding water is extremely rare,if your stove has an open vent lay a washer with a bolt through it over the hole so if it gets go hot it will push it out of the way.   It would work well on those with 1" open ports in the top
monty3077
« Reply #10 on: February 17, 2013, 07:48:52 AM »
Would you burn much more wood raising the temp from the factory setting to 180 on 190 off?
« Reply #11 on: February 17, 2013, 09:27:26 AM »
I don't think you could notice the difference in wood use
boilerman
« Reply #12 on: February 17, 2013, 02:44:30 PM »
At -20 below temps over a week long period, I have experimented to the best of my ability to fill my furnace with the same amout and size of wood each day. Operating furnace at 190-180 and at 175-165 and noticed absolutely no difference if wood usage. So with my indoor forced air system, I went back to the 185-175 CB factory setting. If I had an indoor boiler and baseboards, it would make sense to run OWF at 190-180 for more heat radiation.
