Author Topic: stove temps and longevity  (Read 18578 times)
victor6deep
  • OWF Brand: Burnrite
  • OWF Model: 228
« on: February 23, 2013, 02:57:19 PM »
Curious how many on this site keep their water treated but run a lower setting than 180 degrees?  Really trying to figure if these lower temp settings can shorten the life of a stove or if this is all BS. This is for those with nongassers-
victor6deep
  • OWF Model: 228
Re: stove temps and longevity
« Reply #1 on: February 23, 2013, 03:30:22 PM »
I appreciate your response. I am just trying to find people on this site with stoves or people they know that have ran them cooler with no issues. Thanks again
« Reply #2 on: February 23, 2013, 04:08:02 PM »
It's not a question really.  It's science.  Just look at any boiler, it doesn't have to be a wood boiler, go look at any gas boiler you want, it's going to have a primary and a secondary loop...
This stuff isn't my opinion, Willie was curious about it himself past year and posted links from the Canadian govt on the dangers of running a boiler to cold.
That's not to say that if you don't do this it's not gonna last, but there are endless cases where cold temps caused a failure.
However,why would one not want to run it at 170-180 and keep return temps proper??   There is no benefits there to be had, so it's not like your sacrificing something so to speak
victor6deep
  • OWF Model: 228
« Reply #3 on: February 23, 2013, 05:03:11 PM »
Scott my only concern is I don't have a insulated door on my stove so I am wondering how much heat I am pissing away.
« Reply #4 on: February 23, 2013, 06:05:10 PM »
I'm sure your losing a little, but unless you see severe condensation and creosote just inside the door I wouldn't worry much
MattyNH
  • OWF Model: 7300E ; S-275
« Reply #5 on: February 23, 2013, 07:06:17 PM »
I guess my question is why would you want to go below 180. Isn't that the "golden number" for heating a house.. Your boiler isn't gonna work any harder if it was set at 150 or set at 180 or whatever desired temp..Just set the temp and forget it..  :D
Crown Royal 7300E (2021)
Aqua-Therm S-275 (2006)
Jonsered 2188
Jonsered 2165
Jonsered 2050
Kubota L3800DT
« Reply #6 on: February 23, 2013, 07:36:31 PM »
teh "golden number" is just for easier figuring when designing a heat load..180 degree water when figuring a delta of 20 (another golden number in design) will carry 10,000 btu per hour (easier figuring in tens)
MattyNH
« Reply #7 on: February 23, 2013, 07:44:57 PM »
When do you see the oil boiler go over 180F to heat a house? No different than my OWB pumping in 180F water..
« Last Edit: February 23, 2013, 07:48:37 PM by MattyNH »
Jonsered 2188
Jonsered 2165
Jonsered 2050
Kubota L3800DT
victor6deep
  • OWF Model: 228
« Reply #8 on: February 23, 2013, 07:46:47 PM »
The only reason I am bringing this thread on is that I have 3 close neighbors running non gassers at 150-160. 2 of these stoves are cozeburn made by profab and the other is a homemade. These 3 stoves have went 5yrs with no issues from what these guys are telling me. I looked inside one of the cozeburns and couldn't belive how dirty it was. I could never run my stove that cold just due to the mess I witnessed. Are these people crazy or do they have a point? That's what confuses me, are they gonna make it to 10yrs and spring a leak? I told them I was running 170-180 and they pretty much laughed at me.
MattyNH
« Reply #9 on: February 23, 2013, 07:51:29 PM »
I guess my question is why are they running the stoves at that temp?..They have no point..
Jonsered 2188
Jonsered 2165
Jonsered 2050
Kubota L3800DT
« Reply #10 on: February 23, 2013, 08:03:47 PM »
running cooler temps (if you have very poor insulated undergground lines) can help with heat loss to the ground as the delta between your water and the earth would be less than if you were moving 180 degree water. (this would also be true even with good insulated pipes but the saving would be very little and not worth the damage that may be done to yoru equipment)
less spread in the delta = less heat loss
of course this delta also works in your home....the lower the water temps going into the house, the less btu per hour you can deliver. it may be possable that you may not be able to heat your home on a severly cold windy night when your heat loss of your home is at its maximum (if the stars line up correctly)
« Reply #11 on: February 23, 2013, 08:09:30 PM »
You laugh back, you are the one doing the research, there the ones who aren't actively seeking knowledge.
Ask them what's so funny?
victor6deep
  • OWF Model: 228
« Reply #12 on: February 23, 2013, 08:12:13 PM »
I laughed just when I opened the door and seen a nasty pile of what was coals and ash I guess. I asked him " so this stuff still burns"? Serious LOL
« Reply #13 on: February 23, 2013, 08:13:34 PM »
I used to do that crap, run it 150-160.   Firebox was always harder to keep clean, and it was before I learned a lot about this stuff
whiteyford1
  • OWF Brand: Taylor
  • OWF Model: 750
  • Make every day count!
    • Wimers Welding Service
« Reply #14 on: February 24, 2013, 04:29:19 AM »
Hey, my observations. I replaced a 1984 Aqua something a year ago. Looked like 1/4 carbon plate. These folk only burnt the worst wood, hemlock slabs green and half rotted stuff. They ran it at 110 or 120 unless it got real cold out. Turns out that thermometer was at a lower elevation in the tank vs the blower control, temp gun says they were int he 140 150 range. Another point is some of the thermal wells for the thermometer extend through the insulation and get a readin from the outer tank. I make sure my control and themometer are at the same elevation since I've determined a 20 to 40 degree difference between top and bottom tank temps, thus transcending.
Just my 2 cents.
Randy
