Pages: [1] 2 3 4
Author Topic: Z-Supply llc  (Read 31885 times)
automan77
  • OWF Brand: ridgewood
  • Just say no to propane
Z-Supply llc
« on: March 02, 2013, 07:04:55 AM »
Anyone ever use this Z supply 3 or 5 wrap pex?
Scott K
Stihl ms 311
Husky 455
St Clair County Michigan
Troy Built 27 ton splitter
mikey37
  • OWF Brand: Ridgewood Stove
  • OWF Model: 7500
Re: Z-Supply llc
« Reply #1 on: March 02, 2013, 09:44:58 AM »
yes! I used the 3 wrap  on my install and i am only losing about 1 deg in a 60 foot run! Ridgewood didn't offer the 5 wrap when i bought my pipe!
Re: Z-Supply llc
« Reply #2 on: March 02, 2013, 02:45:47 PM »
Yes, I used it from my house to my outdoor hot tub, about 50 feet but have only had it for a couple years. No complaints from my experience, I brought each end up out of the ground a bit and sealed with their flanges to try to ensure no exterior water could get in the "conduit", also my ground water is not a problem in the area where I buried it. This product has been discussed here before and people have questioned the ability of water to possibly lay in the pipe, or condensate in the pipe but i have had no problems with this run and my return temps are consistent, I have gauges on supply and return in the house, also there is no snow melting above my run and it is fairly shallow (about 2'). I used the 5 wrap.
They only started making 5 wrap this year so you either have 3 wrap or another brand.
automan77
Re: Z-Supply llc
« Reply #3 on: March 02, 2013, 05:30:12 PM »
still leaning towards thermopex but my wallet is  not.  I just  dont want no problems
Scott K
Stihl ms 311
Husky 455
Re: Z-Supply llc
« Reply #4 on: March 02, 2013, 05:37:47 PM »
Ditch preparation is more important than the pipe....  If you have sharp rocks both will eventually fail..
automan77
Re: Z-Supply llc
« Reply #5 on: March 02, 2013, 05:57:13 PM »
mostly good old clay in my yard.
Scott K
Stihl ms 311
Husky 455
Re: Z-Supply llc
« Reply #6 on: March 02, 2013, 05:58:50 PM »
The z-supply 5 wrap probably will have less heat loss than the thermopex.
automan77
Re: Z-Supply llc
« Reply #7 on: March 02, 2013, 06:18:34 PM »
I'm gonna see what kind of   price craig   from  ridgewood  can give me on the 5  wrap
Scott K
Stihl ms 311
Husky 455
Re: Z-Supply llc
« Reply #8 on: March 02, 2013, 06:45:38 PM »
I've got it for $7.15 w/free shipping if you can't get a better deal there
automan77
Re: Z-Supply llc
« Reply #9 on: March 02, 2013, 06:48:02 PM »
thats for the 5 wrap?
Scott K
Stihl ms 311
Husky 455
Re: Z-Supply llc
« Reply #10 on: March 02, 2013, 06:52:24 PM »
Yes sir....  I like it a little better than the z stuff as well, the tile is much tougher
martyinmi
Re: Z-Supply llc
« Reply #11 on: March 02, 2013, 07:07:39 PM »
Scott, would a guy be able to pull that 5 wrap stuff through a 6" pvc?
I'm planning on replacing my thermopex this summer, as it is thawing the ground in two spots. I have access to 200' of FREE 6" pvc, so I thought I'd put the 5 wrap inside the pvc. Any thoughts?
Newholland TZ-25da
30+ Chain Saws
'05 Dodge Diesel
Michigander
TSC 35 Ton Splitter
Re: Z-Supply llc
« Reply #12 on: March 02, 2013, 07:52:48 PM »
Sounds like a great idea to me..  I am most certain it will go through it without the tile, not sure with the tile though.  I would think doing it that way would be one tough package as long as you had it all sealed good, which I know you would
The 5 wrap I carry in test lost 3.1 degrees in a 500' loop flowing 5gpm.
0.62 degree heat loss per 100'
« Last Edit: March 02, 2013, 08:10:49 PM by Scott7m »
Re: Z-Supply llc
« Reply #13 on: March 02, 2013, 07:56:15 PM »
It is 5-3/4" OD so if it is straight it should go through.
The Z-supply 5 wrap testing had .48 degree temp drop per 100 feet.
Re: Z-Supply llc
« Reply #14 on: March 02, 2013, 08:10:11 PM »
I know but I had a bad experience with it a while back..  I was carrying a roll of it with my forklift and dropped it, it just landed in the driveway.  I stood it up and looked not expecting to see anything, but I found a lot of gravel imprints and 2 little holes where it actually poked through.. Just from a fall in the driveway, it made me leery of it, but could have been a freak thing
Pages: [1] 2 3 4
