Author Topic: Hot water heating in Spring and Summer months?  (Read 16843 times)
jack1243
  • OWF Brand: 500 gallon Hick Water Stove
  • OWF Model: 50003212008
« on: March 09, 2013, 11:58:04 AM »
I must say I'm pleased with my unit for heating the house this Winter. It has paid for itself in less then 3 months as we have seen our electric bill go from $1700.00+/- a month to about $200.00 a month. Take that savings x 4 Winter months and we actually made money on the install. However, with warmer weather on the rise I'm wondering how often do you all fire your boilers to heat the hot water for the house. I know on days when we have 65 degree weather my boiler will jump to over 200 degrees if I don't keep an eye on it. I'd like to hear what you all do to keep that golden 180 in the Spring and Summer months when we are not heating the house.
hoardac
  • OWF Brand: Heatmaster G-200
Re: Hot water heating in Spring and Summer months?
« Reply #1 on: March 09, 2013, 12:10:00 PM »
I set it at about 160 and it usually does not go over-temp. I have a older boiler not one the newer efficient ones so I do not know about those types.
« Reply #2 on: March 09, 2013, 01:38:44 PM »
If its spiking over, u have an air leak.  Try to look for air leaks, a good tight stove should allow you to to heat all summer if need be
swede
  • OWF Brand: shaver 165
« Reply #3 on: March 09, 2013, 01:47:11 PM »
Much smaller fires in the summer works for us otherwise temps can over run.
the smoke don't mean its broke
MattyNH
  • OWF Model: 7300E ; S-275
« Reply #4 on: March 09, 2013, 09:01:22 PM »
I would have to agree with Scott..Your boiler shouldn't be spiking over because you have your boiler set at 180F on a 65F day
Crown Royal 7300E (2021)
Aqua-Therm S-275 (2006)
Jonsered 2188
Jonsered 2165
Jonsered 2050
Kubota L3800DT
TLuckoski
  • OWF Model: 5036
« Reply #5 on: March 10, 2013, 07:03:57 AM »
Not having to put up with the hassle of keeping a fire going in the summer I'll pay the $30.00 a month to the power company.
MattyNH
« Reply #6 on: March 10, 2013, 08:05:20 AM »
I run my oil boiler for hot water during the summer months..OWB just doesn't run enough during the summer months..
Jonsered 2188
Jonsered 2165
Jonsered 2050
Kubota L3800DT
« Reply #7 on: March 10, 2013, 09:49:21 AM »
$30?  You live alone?
In months such as April I have went and not used wv or heat the entire month, but by simply not heating my water the bill would go from $85-$100 up to $160-$175
jam
  • Newbie
  • OWF Brand: central boiler
« Reply #8 on: March 11, 2013, 08:39:41 PM »
I burn mine untill the weather gets too warm (mid May) simply for the hot water. its not that its cheaper, its just so much hotter. we get spoiled
Drivebymashing
  • OWF Brand: Earth Outdoor
  • OWF Model: 305 Bear Cub
« Reply #9 on: March 14, 2013, 05:23:07 PM »
Same here after the two decently long showers no hot water left on electric.With the boiler
IT keeps getting hotter the more showers you take.NO cold baths for my 19 month old little girl.
Husqvarna 445
Husqvarna 262xp
Husqvarna 55
2004 Corvette Z06
1971 Deuce and a half 10x10
muffin
« Reply #10 on: March 15, 2013, 07:25:00 AM »
I run mine year round.  Never had any issue with over temps.  Usually only load it every 3 days in the summer.
mw10737
  • OWF Brand: Empyre
  • OWF Model: 250 Deluxe
« Reply #11 on: March 29, 2013, 10:41:37 PM »
i ran mine all last summer .  even when it was 95 degrees here in Iowa in the late summer it never overheated.
Only thing i noticed is i had to put about  a 1/2 gallon of water in it this fall.. i suppose it may evaoporated a bit through the summer.  but besides that as long as you have no air leaks you should have no problems running through summer.'
And ya i think i would throw a few pieces in it every 3-4 days.. kinda gives you a good feeling all summer,, but then when it gets cold it seems like its burning alot..  but by this time when i starts warming up again it gets put back in to prespective...
I love the hot continous showers all summer.... enjoy
Empyre Deluxe 250( NON-GASSER)
MS660 Magnum-36"
MS271-20"
018C-14"
2007 GMC Crew Cab Duramax
Plainfield, Iowa
johnybcold
  • OWF Model: Classic E1400
« Reply #12 on: March 30, 2013, 05:51:31 AM »
I am probaly gonna install a electric water heater, last year I used a ton of oil over the summer
old truck
old craftsman chain saw
Polaris Sportsman 500HO
mw10737
  • OWF Brand: Empyre
« Reply #13 on: March 30, 2013, 06:20:44 AM »
Johny..
You dont have a plate  exchanger for your DHW?  Kinda confused what you mean by oil?
MS660 Magnum-36"
MS271-20"
018C-14"
Plainfield, Iowa
« Reply #14 on: March 30, 2013, 07:46:59 AM »
Many of you may not know this but some Hick Water Stoves don't have automatic drafts. If you are using a furnace where you manually open and close the draft it is very hard to regulate during the spring, summer and fall. Hick mostly uses the furnace design that was common 20 or 30 years ago with no ash pan or grates, manual draft, small fire box, large water jacket, DHW coil in furnace.
