Author Topic: Need Advice on OWB - New User  (Read 20734 times)
caprice_96
« on: April 02, 2013, 08:50:01 PM »
We have a 3 year old home about 1750 sq ft main level and same in the basement, along with a 900 sq foot garage (12' ceilings).  The house is currently heated with a NTI Ti 150 propane boiler, forced air for the main level of the house, radiant floor for the basement and garage.  The boiler also does the domestic hot water (we have a 60 gallon holding tank).  The house is fairly well insulated (R-40+ Attic, R24 exterior walls house and garage).   We live in northern Ontario Canada climate and have lots of wind exposure.  Propane bills are getting expensive, so I am looking at a OWB to save money in the long term.  At this point I am thinking of sticking to a non-gasser stove, to have the ability to burn anything and to keep the stove simple.
I can easily get a Portage and Main, Central Boiler or Heatmor boiler (so far).  I was looking at the Portage and Main BL28-40 (new model), the Central Boiler 5036, or the Heatmor 200 CSS.  Any opinions or experiences with any of the above?
The new Portage and Main model looks impressive with the brick lined fire box and its claims at burning a high efficiency rates without being a gasser.   But it is a new untested model, not sure hoe different it is from the old ML-30.
BL28-40 Outdoor wood furnace by Portage and Main
The Central seems to be a tried and true design.  A good friend has had one for 10 years and swears by it.  It seems to be an old and proven design, but maybe inefficient.
The Heatmor is stainless steel which sounds good, but then the competitors say that stainless has cracking problems.
How much smoke does a non-gasser produce?  Does the chimney's on these hae to be higher than the house peak if the unit is close to the house?  We have strong winds, and the location I am thinking will have the house down wind (generally) from the stove.  The garage is on this side and is very tall.
I am sure I will have lots more questions as time goes on, looking forward to some discussion.
leolends
  • OWF Brand: Heat Master
  • OWF Model: 5000e SS
Re: Need Advice on OWB - New User
« Reply #1 on: April 02, 2013, 09:00:42 PM »
First season with my Heat Master 5000e and love it! I looked at all the same ones you posted and am happy that I went with Heat Master.
« Reply #2 on: April 03, 2013, 08:54:23 AM »
 I sell Heat Master and have sold hundreds over the years and have never had one crack even when its run with no water. Heat Master and Heatmore both use 409 stainless. I believe many people get confused between furnaces made from 409 and furnaces made from 304, Hardy and Empyre for example. 304 will crack much easier than 409.
caprice_96
« Reply #3 on: April 05, 2013, 10:24:54 AM »
What made you decide on the Heatmaster?  What made you choose it over the others?  I haven't found anyone in my area who sells them but I will look into it.
Yoderheating,
thanks for the info regarding the differences in Stainless steel.
« Last Edit: April 05, 2013, 10:27:07 AM by caprice_96 »
caprice_96
« Reply #4 on: April 05, 2013, 10:32:23 AM »
Okay, I have a few more questions.
 I noted that the P&M model only has about 90 gallons of water, the Heatmor is about 114, and the Central is 196.  Why is there such a difference in the water capacity?  Wouldn't more water be better to prevent cycling of the stove?
It seems the Heatmore and P&M have forced draft with fans.  Are these fans highly prone to failure? A friend of mine said they fail very often  Are they normally covered under warranty?  Would a fan draft cause the fire to heat up too quickly and strees the metal, vs a natural draft?
What are your opinions on round vs a square fire box?
Any other advice is appreciated.
Thanks.
dolphin13
  • OWF Brand: heatmor
  • OWF Model: 400
« Reply #5 on: April 05, 2013, 12:31:08 PM »
I am in year 1 w/ my 200 heatmor and have been very pleased,I did a fair amount of research before purchasing and I decided on heatmor knowing several people who had owned them for 10 years w/o any major issues.I like the forced draft fan and have not heard of them being a problem.I also really like the way you can auger the ashes out the back with out sucking up a face full of smoke.Jus my 2 cents.
« Reply #6 on: April 05, 2013, 12:53:27 PM »
Fans rarely ever go bad.  Fans normally have a 1 year warranty but I've got a lot of furnaces out there and I've only had 1 fan failure since 09
Round vs square, round has fewer welds but not many have any issues with any of that
409 is fine
Heat up to quickly and stress metal!? No, everything has water touching it, steel is only as hot as the water.  No damaging it that way
Water capacities, not a big deal to me either, I've heated my home with stoves that held 265 gallons and stoves that held as little as 55 gallons of water.  No difference..  Idle time may increase with larger capacity and that also can lead to more creosote and a dirtier stove.
« Reply #7 on: April 05, 2013, 07:34:58 PM »
 The biggest thing I see with large water amounts or no draft fan is more creosote because they idle to much. The best furnaces I've watched burn had smaller water capacity, draft fan and some sort of bypass that allowed the heat to be collected in the water. I've been told 1 BTU is sufficient to heat 1 lb of water through a temperature change of 1 °F, if this is true a 100 gal furnace would hold 8,000 btu between draft cycles if it was on a 10 degree differential ( hope my quick math is correct). I like for the furnace to cycle every hour or two on a really cold day and several times a day on the warmest day. If you can determine how many btu's you currently use by looking at your current heating bills you should be able to tell what size of furnace you will need.
johnybcold
  • OWF Model: Classic E1400
« Reply #8 on: April 06, 2013, 06:36:17 AM »
Support from the dealer is big during install and you first few months, pick a brand with a good local presence
old truck
old craftsman chain saw
Polaris Sportsman 500HO
caprice_96
« Reply #9 on: April 07, 2013, 08:10:52 AM »
Thanks again for the great advice.
So if water cpacity has no real effect, why is there such a variation is capacities for similar stoves?
What about the fibreglass vs spray foam insulation.  P&M and Heatmore stoves say they use fibreglass.  Wouldn't this be prone to rodents damaging it, or the heat shrinking it?  Spray foam seems good, and I am not sure that I buy the fact that it may promote corrosion by holding moisture against the metal.
« Reply #10 on: April 07, 2013, 09:34:54 AM »
Different ideas, selling points mainly.  If everyone has a 100 gallon water jacket and you make a 200, you suddenly appear different
Fiberglass is fine, it don't break down at all and does a good job, never seen rodents in it personally
Spray foam works, is it better than the r-30 to r-40 fiberglass???   Snow lays on roofs of both types
Spray foam can hide a pin hole leak for years, then when it does show up, it's way to late, that's one disadvantage
caprice_96
« Reply #11 on: April 07, 2013, 08:56:41 PM »
I have seen mice burrow into the pink fibreglass doing house renos.   They love that stuff, but I would assume that the stoves would use something different from what's in the walls of a house.  I wonder why nobody uses a stone wool insulation like Roxul:
http://www.roxul.com/products/residential/roxul+comfortbatt
Is there some sort of antifreeze that can be put in the water for in the winter if you travel and leave the wood boiler off for several days or more?
Also, has anyone on here installed one of these systems with an existing gas boiler?  Is it something a DIYer can do, or will this have to be done professionally?
« Reply #12 on: April 07, 2013, 09:11:06 PM »
Yea you can tie it to a boiler with a plate exchanger, it could be a DIY project
Most folks leave a pump on so water is always flowing from there stove, glycol is avsilable but hardly affordable
The fiberglass they use is nothing different, at least not on any brand that I've saw.  However never seen it be an issue
Crow
  • OWF Model: BL 28-40
  • Eastern Ontario
« Reply #13 on: April 07, 2013, 09:20:24 PM »
  At least with the smaller water capacity the new P&M, A/F wouldn't be as expensive - if needed.
baldwin racing
« Reply #14 on: April 07, 2013, 10:10:50 PM »
you can mix glycol and mix it with water 50/50 it is a type of antifreeze and wont freeze if mixed properly.....
kelly
husqvarna 357 xp
farmall H
