Author Topic: plate exchanger diagram  (Read 6378 times)
automan77
  • OWF Brand: ridgewood
  • Just say no to propane
« on: May 01, 2013, 07:26:28 PM »
does anyone no where I can find a good diagram of how to hook up a plate heat exchanger or some pics, Im thinking about installing my own but have very little plumbing skills.
Scott K
Stihl ms 311
Husky 455
St Clair County Michigan
Troy Built 27 ton splitter
WoodMOJoe
Re: plate exchanger diagram
« Reply #1 on: May 01, 2013, 08:29:54 PM »
I drew a schematic sketch of my entire system, with plate exchanger, here in this thread:
http://outdoorwoodfurnaceinfo.com/forum/index.php?topic=3692.0
The link to my sketch is at the bottom of page 1, check it out and see if it might help you.
« Reply #2 on: May 08, 2013, 06:40:46 AM »
I am waiting on a shipment of 50 plate heat exchangers ( should be in today ) I am going to build up a manifold that makes sense for adding water to the boiler from inside as well as purge ports for future cleaning without removing the plate exchanger and it also has a port to inject air to blow out the lines in case it has to be shut down in the cold season. I should have one done this week and will post a picture of it. note I don't cheap out on parts, copper and brass only.
