Author Topic: Water to air exchanger location  (Read 7731 times)
woodwalker2010
« on: May 29, 2013, 06:13:44 PM »
I'm getting ready to order materials to hook up my owb I just purchased, but was wondering about my water to air heat exchanger for my forced air. My question is, can I install the hx on the return side of the blower on the furnace and let the blower pull the warm air through it as opposed to above the blower? I have more room in this location because of the AC coil and duct work above the blower. I can put the hx above the AC coil but it would be a heck of a lot easier if I put it below it. Thanks.
Re: Water to air exchanger location
« Reply #1 on: May 29, 2013, 09:21:23 PM »
you want it on the "clean" side of the filter. you do not want your exchanger to act as a pre filter and clog up with dust and dirt
Dano
  • OWF Model: ml30
« Reply #2 on: May 30, 2013, 07:09:28 AM »
I put mine on the return side . I just moved the filter above it. Works just fine
Drivebymashing
  • OWF Brand: Earth Outdoor
  • OWF Model: 305 Bear Cub
« Reply #3 on: May 30, 2013, 03:44:15 PM »
I also put mine on return side but couldnt fit any filters right above it
SO i can had to put filters in all return ducts in house i have three filters before it now...
Husqvarna 445
Husqvarna 262xp
Husqvarna 55
2004 Corvette Z06
1971 Deuce and a half 10x10
« Reply #4 on: June 10, 2013, 10:23:24 PM »
If you'd want to take some pics and text/email them to me I can help take some of the guesswork out of it for you, let me know if I can help.  My number is in my signature at the bottom
woodwalker2010
« Reply #5 on: June 13, 2013, 07:26:31 PM »
Thanks guys. S7M, I will get some pictures for you. I'm leaning towards putting a 16x18 above the AC coil, I think I can squeeze it in but maybe the return would be less of a headache, as far as installation goes. Thanks again everyone, awesome forum by the way. Lots of great info on here.
« Reply #6 on: June 13, 2013, 08:15:56 PM »
I'd try to keep it on the supply side if I could, once you go to return side u have to make a new spot for your filter
